Calculating Pressure Drop - BCs
Old   February 25, 2013, 16:27
Default Calculating Pressure Drop - BCs
spoon is on a distinguished road
I am trying to simulate flow over an obstruction in a pipe in order to calculate pressure drop across the pipe. I know the flopw rate through the pipe and I also know that nominally the inlet pressure is 100 Pa.
I am not sure how to go about setting up my boundary conditions for this calculation.
At the moment my toughts are:
Pressure:
Inlet - Fixed Value
Outlet - zeroGradient (??)
Walls - zeroGradient
Velocity:
Inlet - fixed value
outlet - inletOutlet with inletValue (0 0 0), not sure what Value option should be here
walls - fixedValue Uniform (0 0 0)
Does this seem correct? I have not done CFD in quite a while now so can't really remember.
I am also wondering the best way to calculate the actual total pressure drop.... Any suggestions here?
Thanks
spoon is offline   Reply With Quote
Old   February 25, 2013, 18:47
Nickolas P
NickolasPl is on a distinguished road
Well if you specifiy the pressure and the velocity at the same boundary it is like you re overdefining your problem. As you have a purely pressure driven flow I suggest to specify zero pressure at the exit and flow rate/velocity at the inlet boundary along with no slip at the walls. Since you know the pressure drop as you say, the software then should calculate the flowrate so that to preserve the mass balance.
Regards,
Nickolas
NickolasPl is offline   Reply With Quote
boundary conditions, internal, pipe, pressre, velocity
pressure drop in the pipe mike.mm FLUENT 6 February 7, 2011 10:31
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
Pressure drop? Munni FLUENT 4 March 25, 2010 14:21
Pressure drop in a heat exchanger Diana FLUENT 5 December 13, 2007 09:33
cyclone pressure drop - reg Subramanian.J FLUENT 2 December 22, 2006 05:34
