[swak4Foam] groovyBC for perfectGas modell
Old   February 25, 2013, 07:50
Default groovyBC for perfectGas modell
aronman is on a distinguished road
Hello everybody!
Excuse me if the question is inappropriate or put up in the wrong forum but I am a beginner OpenFOAM user. I encountered the following problem:
I wanted to test groovyBC in the heatTransfer/buoyantSimpleFoam/buoyantCavity tutorial that I put it in 0/T:
hot
type groovyBC;
valueExpression "307.75";
// variables "whT3a_fin{patch'Holeaii/fin}=sum(K*snGrad(T)*area()) TT3a{patch'Holeaii/fin}=max(T);whT3a_flowfield{patch'Holeaii/flowfield}=sum(2*snGrad(T)*area());N=5000;W=1800;" ;
value uniform 307.75;
The solver stops at reading in the thermophysicalProperties. I've checked it previously that the perfectGas causes it
thermoType hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>;
My question is how to eliminate this problem? Some kind of 'libs' in the controlDict?
[These didn't solve it:
libs ( "libOpenFOAM.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" "libcompressibleRASModels.so" "libgroovyBC.so" "libthermophysicalFunctions.so" "libbasicThermophysicalModels.so" "libincompressibleTransportModels.so" "libthermophysicalFunctions.so" );
Thanks in advance,
aronman
aronman is offline   Reply With Quote
Old   February 25, 2013, 16:23
Assistant Moderator
Bernhard Gschaider
Originally Posted by aronman View Post
Hello everybody!
hot
type groovyBC;
Thanks in advance,
aronman
With "the solver stops" you mean what? Is there an error message?
The same case works if you replace the type in the boundary condition with fixedValue?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 26, 2013, 03:54
Default re
Yes, the solver stops and gives the following error message:
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#4 Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::hPsiThermo(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#5 Foam::basicPsiThermo::addfvMeshConstructorToTable< Foam::hPsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > > >::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
#6 Foam::basicPsiThermo::New(Foam::fvMesh const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libbasicThermophysicalModels.so"
in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/buoyantSimpleFoam"
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
The original BC was fixed value in this tutorial (heatTransfer/buoyantSimpleFoam/buoyantCavity) and it ran. Then I replaced the BC only at the 'hot' boundary for testing groovyBC. I suspect (checked it) that the perfectGas thermophysical modell doesn't like groovy, but I don't know why.
Old   February 26, 2013, 05:17
Assistant Moderator
Bernhard Gschaider
I guess this is a problem with the current release that is already fixed in the dev-version. Problem is that during the initialization the BC evaluates to 0 and T=0 is not good in the perfect gas equation.
To verify that this is the problem: set "type fixedValue; value uniform 0;". Should give the same stack-trace.
As a workaround add "refValue $value;" (of course after you reset value from 0 to the proper value)
Old   February 26, 2013, 08:27
Thank you very much for your answer. It solved the problem.
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 07:16
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 08:49
