-   -   inject different sized particles (http://www.cfd-online.com/Forums/openfoam-solving/113796-inject-different-sized-particles.html)
czhao86 February 26, 2013 18:47
Hi Foamers,
I do not have any idea about injection type, except the doc I find in the tutorials. Now I can only inject one sized particles.
        sizeDistribution
            type        fixedValue;
            fixedValueDistribution
                value  0.2;
How can I inject two sized particles, like 0.1 and 0.2 at the same time?
niklas February 27, 2013 03:45
If its important that the size is either 0.1 or 0.2, I would use 2 injectors
czhao86 February 27, 2013 11:16
Thank you for your reply.
So should I use two 'CloudProperties' files or two injection in the same 'CloudProperties' file?
czhao86 March 6, 2013 15:25
does anyone have some ideas?
ris March 6, 2013 16:57
Hello czhao86,
I just saw this and it might be useful to you http://www.openfoam.org/version2.2.0...-modelling.php
You could specifiy two injectors of the same model having different size distributions.
Also you only need one sprayCloudProperties file.
regards,
ris.
czhao86 March 6, 2013 18:08
Thank you for your reply, ris.
I am using icoUncoupledKinematicParcelFoam, whose injection is like the following
solution
    active          true;
    coupled        false;
    transient      yes;
    cellValueSourceCorrection off;
    interpolationSchemes
        rho            cell;
        U              cellPoint;
        mu              cell;
    integrationSchemes
        U              Euler;
    sourceTerms
        schemes
        // Scheme and under-relaxation factor
          U              semiImplicit 0.5;
//        U              explicit 1.0;
constantProperties
    parcelTypeId    1;
    rhoMin          1e-16;
    minParticleMass 1.0e-15;
    rho0            1;
    youngsModulus  6e8;
    poissonsRatio  0.35;
    constantVolume  false;
subModels
    particleForces
        sphereDrag;
        gravity;
    injectionModel manualInjection;
    dispersionModel none;
    patchInteractionModel standardWallInteraction;
    heatTransferModel none;
    surfaceFilmModel none;
    collisionModel pairCollision;
    radiation off;
    manualInjectionCoeffs
        massTotal      0;
        parcelBasisType fixed;
        nParticle      1;
        SOI            0;
        positionsFile  "kinematicCloud0Positions";
        U0              (0 0 0);
        sizeDistribution
            type        fixedValue;
                value  0.1;
pairCollisionCoeffs
        // Maximum possible particle diameter expected at any time
        maxInteractionDistance  0.1;
        writeReferredParticleCloud no;
        pairModel pairSpringSliderDashpot;
        pairSpringSliderDashpotCoeffs
            useEquivalentSize  no;
            alpha              0.12;
            b                  1.5;
            mu                  0.52;
            cohesionEnergyDensity 0;
            collisionResolutionSteps 12;
        wallModel    wallLocalSpringSliderDashpot;
        wallLocalSpringSliderDashpotCoeffs
            walls
                youngsModulus  1e10;
                poissonsRatio  0.23;
                alpha          0.12;
                b              1.5;
                mu              0.43;
    standardWallInteractionCoeffs
        //type            stick;
        type            rebound;
cloudFunctions
I am not sure where to add the second injection, as the format is a little different, but certainly thank you for your reply.
czhao86 March 7, 2013 17:20
Originally Posted by ris (Post 412089)
Hello czhao86,
regards,
ris.
I figured out openfoam 2.2.0 has a different format of 'injectionModels' even in the tutorials, compared to 2.1.1.
I saw this webpage but did not realize its importance.
Thank you for giving me a hint.
camzis June 16, 2015 05:15
Diifferent numbers of particle injection?
Dear Foamers,
I'm currently working with the solver iconUncoupledKinematicParcelFoam (lagrangian).
I need to inject a different number of particles at each time step.
I'm currently using the model "patchInjection" in the file kinematicCloudProperties.
The problem is, I dont know how to make the number of particels vary.
Is there a way to force the number of particles to vary by wether providing a table (for number of particles vs. time) or as a function?
Any suggestions, ideas are very welcome.
Please, my master thesis depends on this.
Regards!
Mamadou.
Dust July 8, 2015 20:06
Normal Distribution
I think you can define the size of particles to be normal distributed. For instance:
sizeDistribution
type normal;
normalDistribution
expectation 0.0001;
variance 2.16e-10;
minValue 0.00005;
maxValue 0.00015;
Hope it helps
Zonghao
