why prandtle is requested while sutherland is defined? |
February 13, 2013, 07:08 |
Ehsan
Rep Power: 26 |
I have definrd sutherland in thermophysical file.but OpenFOAM 2.1.1 complains about Pr.while this error doesnt occur in 2.1.0.
ehsan@Ehsan-com:~/Desktop/Takhlie/takhlie$ pyFoamPlotRunner.py --hardcopy --with-courant --no-pickled-file rhoCentralFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : rhoCentralFoam Date : Feb 13 2013 Time : 15:31:07 Host : "Ehsan-com" PID : 8139 Case : /home/ehsan/Desktop/Takhlie/takhlie nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package ePsiThermo<pureMixture<sutherlandTransport<specieThermo<janafThermo<perfectGas>>>>> Reading field U Creating turbulence model Selecting turbulence model type laminar Reading thermophysicalProperties --> FOAM FATAL IO ERROR: keyword Pr is undefined in dictionary "/home/ehsan/Desktop/Takhlie/takhlie/constant/thermophysicalProperties::mixture::transport" file: /home/ehsan/Desktop/Takhlie/takhlie/constant/thermophysicalProperties::mixture::transport from line 39 to line 40. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 400. FOAM exiting Code:
ehsan@Ehsan-com:~$ icoFoam -help Usage: icoFoam [OPTIONS] options: -case <dir> specify alternate case directory, default is the cwd -noFunctionObjects do not execute functionObjects -parallel run in parallel -roots <(dir1 .. dirN)> slave root directories for distributed running -srcDoc display source code in browser -doc display application documentation in browser -help print the usage Using: OpenFOAM-2.1.1 (see www.OpenFOAM.org) Build: 2.1.1-221db2718bbb |
February 14, 2013, 15:17 |
Ehsan
Rep Power: 26 |
any related idea is appreciated on the subject of the problem.
February 26, 2013, 18:15 |
Ehsan
Rep Power: 26 |
any idea exists?
March 8, 2013, 04:25 |
Ehsan
Rep Power: 26 |
question is persistent yet.
[ICEM] How can I define different zones in ICEM? | llrr | ANSYS Meshing & Geometry | 14 | February 12, 2017 13:44 |
UDF link fortran source | yorelchr | Fluent UDF and Scheme Programming | 0 | February 7, 2013 03:44 |
using METIS functions in fortran | dokeun | Main CFD Forum | 7 | January 29, 2013 04:06 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
OpenFOAM13 for Mac OSX Darwin 104 | hjasak | OpenFOAM Installation | 70 | September 24, 2010 05:06 |
