how can treat with interface intering from gambit? |
February 27, 2013, 16:51 |
Ehsan
Rep Power: 26 |
i have an interface thats between two parts of mesh.how can behave with it so that i can calculate the mass flux through it?
What will be its type? |
March 2, 2013, 17:44 |
Ehsan
Rep Power: 26 |
any guidance?
March 5, 2013, 06:31 |
Ehsan
Rep Power: 26 |
what should change to OF recognize a interface(a patch between two sets of meshes)?
March 10, 2013, 15:39 |
#4 | |
Rep Power: 13 |
just make your mesh and after running the mesh in fluent after iteration and solving the problem go to: fluent> surface tab> define a line for 2D model or a plane for 3D model at the place of your interface then in plot tab> xy plot choose the line or surface that you make in fluent and see the result |
March 13, 2013, 03:38 |
Ehsan
Rep Power: 26 |
thanks.i want to use interior patch in openfoam not fluent.
I have a doubt how to specify it in OF when i enter mesh from gambit. I want to calculate mass flux through this patch(that is named interior in gambit) |
March 13, 2013, 11:34 |
Marco A. Turcios
Rep Power: 28 |
I don't think you need a patch, just define a faceZone (be sure to orient it) then do your calculation inside the solver, with function objects or swak4Foam.
March 13, 2013, 16:52 |
Ehsan
Rep Power: 26 |
thanks dear Marco.
Excuse me for this banal question to a expert like you. How can define a face zone?is it defined in blockMeshDict? |
CFX13 Post Periodic interface | EtaEta | CFX | 7 | December 8, 2011 17:15 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
