February 28, 2013, 09:41 |
pipe flow OpenFOAM
Hi!
I am new to OpenFOAM and I have to use OpenFOAM for my diploma thesis. I want to compare the results of OpenFOAM with simple examples, which can be calculated by hand. My first example is a straight pipe flow and i already have problems. My geometry is a 1mx1m quadratic tunnel with a length of 20m. I defined all boundary conditions (inlet 5 m/s, outlet pressure=0, wall ). The flow is turbulent and i use the komegaSST model for the turbulence. i simulated the flow with different mesh resolutions (various y+). The y+ values i were 30, 50, 100, 150. Now the problem is that i calculated the pressure loss analytically and the OpenFOAM results aren't even near the exact results. They are 30% (and for high y+ values even more) away from the exact results. Could anybody please help me with my problem? Thanks, Daniel |
March 4, 2013, 16:44 |
Ryan
I can think of a few reasons why your pressure drop is too high.
Are you using fully-developed flow in your analytical calculations and are you specifying a flat velocity profile at the inlet? Otherwise, can you show a couple of pictures of your mesh and your results? |
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) | florian_krause | OpenFOAM | 22 | June 13, 2013 21:25 |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 11, 2012 23:18 |
[ASK] Flow in Corrugated Pipe with FLUENT | Primadhani | FLUENT | 1 | May 11, 2011 20:41 |
Pipe Flow | Saima | CFX | 1 | January 10, 2011 16:41 |
Turbulence intensity in fully devloped pipe flow - Reference | Shocktrain | Main CFD Forum | 0 | October 14, 2010 06:58 |
