April 28, 2013, 08:53 |
#21 |
Vivek
Thanks Bruno!!
will do it! and i am using Openfoam version 2.2.0. |
April 28, 2013, 10:25 |
#22 |
Vivek
Hi Brunos,
When i try to modify the reactingFoam model with my mesh i get the following error. [COLOR="Red"] Create time Create mesh for time = 0 Reading g Creating reaction model Selecting combustion model PaSR<psiChemistryCombustion> Selecting chemistry type { chemistrySolver ode; chemistryThermo psi; } Selecting thermodynamics package { type hePsiThermo; mixture reactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Selecting chemistryReader foamChemistryReader #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 Uninterpreted: #3 Foam::fvPatchField<double>:perator/=(Foam::fvPatchField<double> const&) at ??:? ... . . . . . . at ??:? #26 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #27 at ??:? Floating point exception (core dumped) Where is the problem??? What should i change? |
May 1, 2013, 23:48 |
#23 | |
Vivek
to understand the problem I tried my geometry in rhoSimpleFOAM. when i encountered this i changed my underrelaxation factors of rho and p. the simulation was running fine. But when i run the case in reactingFOAM the problem is there. I am wondering is there any way i can change parameters ?(as i did for rhoSimpleFOAM) so i can run my simulations. |
May 5, 2013, 12:11 |
#24 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Lasse,
By the way, you mentioned in the share message, that when you activate the gravity, that the solver/solution would diverge. There are two possibilities:
Bruno
May 5, 2013, 18:32 |
#25 |
wow, i'm so sorry. i discovered that myself the same day(just after) i updated the dropbox case and corrected it. mustve forgot to upload the corrected one. I will however test higher k-Epsilon values. i'll update that blockmeshdict asap
May 6, 2013, 20:54 |
#26 |
Hello!:-)
i updated the case. the solution is not diverging now, however... i'm struggling with what seems to me as reversed flow from the outlet patch. at both top and bottom corner along the outlet(although one is located on the top patch) patch are strong velocity fields, oppositely directed. at the top is inflow, bottom outflow. see attached pictures for visual on how ridiculous my situation is. All taken at t=1s: This is full mesh 3D: Ufields5.jpg This is top and outlet only. The blue field on the top patch is -23m/s in negative X-direction...topandoutlet_UX_may7.png Finally a picture of my outlet patch. How did it come to this? outlet_UX_May7.jpg sine the issue arised after extracting the outlet patch from the top patch, and the problem shows on top and outlet patch, these boundary conditions are what i've looked into and played with the most. i made a table with an overview of my current conditions in the 0-folder. bcandparameters_table_may7.jpg (This image is in the dropbox folder in full size. Also the full case is updated.) with this new issue i feel like i'm stumbling around in the dark looking for the solution in tutorials while not able to rationalize where it comes from, but i continue to look into it of course! And thanks a lot for all help you have provided me already. It's really generous Regards, Lasse |
May 7, 2013, 04:08 |
#27 |
Update: i've tried to eliminate possible sources of error, but in failing to locate the root cause i have now made the case a laminar one with a viscosity a 1000 times higher than normal. still, after just t=1s the entire domain is showing unrealistic velocities..
Full domain from side: laminar_full.jpg Air inlet only: airpatch_laminar.jpg So the question is, what is causing the domain to obtain these velocity fields.. I'm in pursuit. Dropbox updated accordingly. Lasse |
October 25, 2013, 05:31 |
Gas dispersion
#28 | |
Alex Lee
Can you share the case files with me too..... my email is alexleekh@singnet.com.sg Thanks |
ch4, error, gas dispersion, komegasst, reactingfoam |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
