Strange behaviour when using LienCubicKE and NonlinearKEShih
Old   September 27, 2007, 05:08
Default Here's a picture of a strange
Håkan Nilsson
hani is on a distinguished road
Here's a picture of a strange behaviour at the surface of a water turbine runner, when using LienCubicKE and NonlinearKEShih in OF-1.4. The surfaces are colored by the turbulent kinetic energy, and everything that is not blue is incorrect. It looks like those colors should belong to some other variable. The behaviour does not appear when using the kEpsilon and RNGkEpsilon models.
I was first thinking that this might be post-processing, but since it appears both in Ensight and in paraFoam there is a risk that this actually affects the solution. The solution yields flow features that I can't explain physically, but they probably origin from this strange behaviour.
I also had a look at the domain decomposition for the parallel simulations, but there is no processor interface exactly in this position.
Did anyone see anything like this before?
Håkan
hani is offline   Reply With Quote
Old   September 27, 2007, 05:24
Default as i posted some weeks ago, i
robert maduta
roberthino is on a distinguished road
as i posted some weeks ago, i had something similar.
i run a turbulent channel flow (normal one and also one with wall suction and blowing). with the nonlinear models ( i tried both with wall functions and lowre) the turbulent kinetic energy and the dissipation were always at one wall. first of all the kinetic energy should be zero at the walls and second in the normal channel flow the behaviour should be axissymetric. nobody could help me with that. i tried everything like playing with relaxation parameters and using the rng k-epsilon field as initial condition etc. how is your velocity field. does it give correct results?
roberthino is offline   Reply With Quote
Old   September 27, 2007, 05:56
Default Looking at circumferentially a
Håkan Nilsson
Looking at circumferentially averaged velocity profiles below the runner, the velocity actually looks fine. But then they are circumferentially averaged, and I expect that there is a difference in different positions in the circumference.
Looking at a pressure iso-surface there is a strange behaviour that might have its origin in the previously mentioned problem. In the following picture there is a non-axisymmetric (and non-periodic) pressure distribution at the runner cone. I am actually looking for this kind of structure, but the problem is that its location is steady in time (in the rotating coordinate system), which it shouldn't be. I also see that the pressure is not periodic on the five blades, so there will be a net force on the runner which there shouldn't be. This non-axisymmetric pressure at the blades is also steady in time in the rotating coordinate system.
Håkan.
Old   September 27, 2007, 06:16
Default the problem looks similar to m
robert maduta
the problem looks similar to mine. i also had problems with the pressure distribution. what are your boundary conditions for inlet outlet? and do you start the simulation with a converged rng-k-epsilon solution as initial condition?
Old   September 27, 2007, 06:47
Default The simulations are started fr
Håkan Nilsson
The simulations are started from a converged kEpsilon solution.
Boundary conditions:
U:
INLE (specified inlet b.c., looks good)
type fixedValue;
value nonuniform List<vector>
OUTL
type zeroGradient;
WALL
type fixedValue;
value uniform (0 0 0);
ROTI (some rotating walls)
type fixedValue;
ROTW (some rotating walls)
type fixedValue;
p:
INLE
type zeroGradient;
OUTL
type zeroGradient;
WALL
type zeroGradient;
ROTI
type zeroGradient;
ROTW
type zeroGradient;
k:
type fixedValue;
value nonuniform List<scalar>
OUTL
type zeroGradient;
WALL
type zeroGradient;
ROTI
type zeroGradient;
ROTW
type zeroGradient;
epsilon:
type fixedValue;
OUTL
type zeroGradient;
WALL
type zeroGradient;
ROTI
type zeroGradient;
ROTW
type zeroGradient;
Håkan.
Old   September 27, 2007, 09:53
Default Have you recompiled using the
E. David Huckaby
david_h is on a distinguished road
Have you recompiled using the bug fix for "TensorI.H" ?
"Tensor bug fix"
This might explain the differening behavior with the linear k-eps models (kEps, RNGkeps,..) which calculate the turbulent production, G, from the square of strain magnitude,
G = 2 * nu_t * magSqr( grad(U) )
as compared to the nonlinear models which calculate the production from a contraction ("&&" operator) of the velocity gradient and the turbulent stress,
G = stress && grad(U)
david_h is offline   Reply With Quote
Old   September 27, 2007, 10:10
Default oh wow thanks for that hint. a
robert maduta
oh wow thanks for that hint. actually what does recompüile means? do i only have to overwrite that certain file on my hardrive or also something else?
Old   September 27, 2007, 10:18
Default and also is that patch working
robert maduta
and also is that patch working as well for openfoam 1.4?
Old   September 27, 2007, 10:29
Default The bug also applies to openfo
E. David Huckaby
The bug also applies to openfoam 1.4 and I don't think "TensorI.H" changed between 1.4 and 1.4.1.
(you might check this before doing a replace)
By recompile, I meant to replace (edit) the existing "TensorI.H" with the posted version and recompile your OpenFOAM library.
Dave
Old   September 27, 2007, 10:45
Default should i recompile the whole s
robert maduta
should i recompile the whole src and applications or only src?
is that the right command?
foam
cd src
./Allwmake
cd ../applications
./Allwmake
Old   September 27, 2007, 10:49
Default I did not include this bug fix
  #11
Håkan Nilsson
I did not include this bug fix in these simulations. That is actually the kind of bug I expected to be the reason for this behaviour.
I hope that I will have the time to test the bug fix soon.
Thank you Dave!
Håkan.
Old   September 27, 2007, 10:53
Default Robert, You only need to re
  #12
Cedric DUPRAT
cedric_duprat is on a distinguished road
Robert,
You only need to recompile from the first wmake you find in your tree: OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM
so, after you changed the TensorI.H, go there and wmake there
this is C++ power :o)
regards,
Cedric
cedric_duprat is offline   Reply With Quote
Old   September 27, 2007, 12:24
Default when do the wmake i always get
  #13
robert maduta
when do the wmake i always get an error message like that:
maduta@linux-hiwi1:~/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM> wmake
make: Warning: File `Make/linuxGcc4DPOpt/dontIncludeDeps' has modification time 10 s in the future
make: Warnung: Mit der Uhr stimmt etwas nicht.
Die Bearbeitung könnte unvollständig sein.
SOURCE=OSspecific/Unix/signals/sigFpe.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -DWM_PROJECT_VERSION='"'1.4'"' -I/home/maduta/OpenFOAM/OpenFOAM-1.4/src/zlib-1.2.1 -IlnInclude -I. -I/home/maduta/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/sigFpe.o
/bin/sh: g++: command not found
make: *** [Make/linuxGcc4DPOpt/sigFpe.o] Fehler 127
what could that be?
Old   September 29, 2007, 06:53
Default hi i managed to overwrite the
  #14
robert maduta
hi i managed to overwrite the TensorI.H file in the Tensor directory.
what i did then is going with the terminal to the /src/OpenFOAM directory and i made the command:
wmake /OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/primitives/Tensor/TensorI.H
after making all the dependencies at the end i get an error like this:
finished, there are no rules to create TensorI.H
someone knows if that could be a compilation error due to ubuntu which i am using because suse didnt work.
or is there any mistake in my commands?
and also does this wrong tensor definition also affect the rsm-models? i guess so cause they also give me wronmg results
it would be nice if someone could help me :-)
Old   October 1, 2007, 06:29
Default Hi Robert! You have to rema
  #15
Assistant Moderator
Bernhard Gschaider
Hi Robert!
You have to remake the libOpenFOAM.so:
cd $FOAM_SRC/OpenFOAM
wmake libso
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   October 1, 2007, 13:28
Default i just want to give an update:
  #16
robert maduta
i finally managed to do a wmake libso in ubuntu with the new TensorI.H file. it all went well but the nonlinear models are still giving wrong results for channel flow, like totally non symmetric. so Håkan Nilsson if you find out something new plz let me know.
Old   May 10, 2012, 11:02
Aniko Rakai
ancsa is on a distinguished road
Hi all!
It's been a while since you wrote here but did someone find out what is wrong with the nonlinear models? I am also trying to use them, first some tests with a boundary layer flow. The results are different from the analytical solution and I thought maybe because from the original Shih paper mentioned in the code the dirac terms, i.e. the double dot products or the gradU are not implemented.
Did someone have the same feeling when comparing with the paper?
Aniko
ancsa is offline   Reply With Quote
Old   January 30, 2013, 05:16
Question generation term
  #18
Jongtae Kim
jkim is on a distinguished road
Is there anyone who knows correct generation term for nonlinear turbulence model?
In all the nonlinear models in OpenFoam, the generation term looks like
G = nu_t * symm(grad(U)) && grad(U) - nonlinear_term (1)
I think the first term of G must be same as one in linear models.
In linear models such as kEpsilon,
G = nu_t * 2 * symm(grad(U)) && grad(U) (2)
= nu_t * 2 * magSqr(symm(gradU))
I can't understand why factor 2 is omitted in eq. (1).
If you know the reason or the correct generation for nonlinear turbulence model, please give your help to me.
Many thanks
jkim is offline   Reply With Quote
Old   March 6, 2013, 09:50
Default Courant number increases
  #19
Akbar Mohammadi Ahmar
akbarMohammadiAhmar is on a distinguished road
Hi all,
When run with the Cubic non-linear model Lien with the linear wall Function Courant number increases sharply and so soloution of problem is stops.
but when run with Nonlinear wall function I haven't this problem.
Please friends help me that how to solve this problem.
Thanks.
akbarMohammadiAhmar is offline   Reply With Quote
Old   March 6, 2013, 10:01
Hi jkim,
I agree with you , Because I work with nonlinear models for example quadratic Shih .
when that me use the first term of G (nu_t * symm(grad(U)) && grad(U)) result of solution
is uncorrect .
I run same model with G = nu_t * 2 * symm(grad(U)) && grad(U)- nonlinear_term that result is very good.
so, I think this approach is correct.
IcoFoam strange behaviour when gravity is included nicasch OpenFOAM Running, Solving & CFD 5 August 29, 2014 10:09
buoyantFoam OF15 very strange behaviour in hotRoom andrea_barbera OpenFOAM Running, Solving & CFD 4 July 30, 2009 09:06
Strange multicomponent source behaviour Zitron CFX 4 July 12, 2007 15:32
Strange Behaviour in CFX-Mesh Kasper CFX 0 May 14, 2007 08:24
Strange behaviour in Coffus Luis Filipe Fabiani Phoenics 0 June 1, 2006 11:23
