-   -   OpenFOAM virtual memory error (http://www.cfd-online.com/Forums/openfoam-solving/114137-openfoam-virtual-memory-error.html)
spoon March 5, 2013 20:12
I am trying to run an internal pipe flow with obstruction simulation. I have succesfully created a mesh using snappyHexMesh and then I have been solving with simpleFoam. I am running openFOAM in ubuntu via virtualbox with a Windows 8 host.
My solution was obviously incorrect and I could see that it was not converging after having plotted residuals; so I decided to increase the density of my background blockMesh mesh in the hope of solving this problem.
My new mesh is built fine with approximately ~1.8M cells, but when I run simpleFoam it begins calculating, finishes the first time step and then quits with the following error:
new cannot satisfy memory request.
This does not necessarily mean you have run out of virtual memory.
It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library.
Aborted.
I gave my virtual machine 5G of RAM so I don't know what the problem is.
Any help would be great,
Thanks
shashi July 12, 2013 07:24
Hi spoon,
Have you found your solution yet ? Does it have anything to do with the virtual memory
I have encountered the same error.
regards,
