Home > Forums > OpenFOAM Running, Solving & CFD
what reasons may make fluctuations in residuals?
Old   March 7, 2013, 07:46
Default what reasons may make fluctuations in residuals?
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
Hi everybody,
residuals are attached.
I work with a modified viscoelasticFluidFoam solver that combined whit buoyantBoussinesqSimpleFoam.
thanks
Mostafa
adambarfi is offline   Reply With Quote
Old   March 7, 2013, 09:13
Nikesh Bhattarai
nikesh is an unknown quantity at this point
Such a small fluctuation in residuals is not a problem. You should take care to see whether ur residual reaches below the convergence tolerance or not! Generally we would set the convergence tolerance to be 10^-5 or 10^-6 or less which depends on user.
In your case, the residuals are not decreasing. They are fluctuating around a mean value and that mean value is of the order 10^-3 for the p-residual and 10^-1 for Uy-residual. As we can see, these are pretty high values. We want our residuals to be as small as possible, thats the general concept.
nikesh is offline   Reply With Quote
Old   March 7, 2013, 09:35
adambarfi's Avatar
Mostafa Mahmoudi
I meant that what might cause this problem????!?
Old   March 7, 2013, 10:11
Nikesh Bhattarai
There could be numerous reasons for your residuals to be so high. We can't point out one reason for sure. However, you might want to recheck your boundary conditions and schemes used and also the mesh criteria first.
Old   March 7, 2013, 10:34
adambarfi's Avatar
Mostafa Mahmoudi
in buoyantboussinesqsimplefoam i just replace the turbulent model with some constants.
alpha, kappa, nu ...
Old   March 7, 2013, 10:47
Nikesh Bhattarai
I might not be able to help you much with this since I don't have experience working on this case.
Maybe somebody with experience in this might!!
Thread Tools
Trackbacks are On
under-relaxation factors -> level of residuals Zigainer FLUENT 17 February 6, 2016 01:12
Inlet fluctuations issue in LES Ivan Main CFD Forum 0 October 15, 2012 12:57
paraFoam not found maysmech OpenFOAM Paraview & paraFoam 26 October 25, 2011 03:14
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
a way to make lots of money quick and easy no lies Dob Main CFD Forum 0 October 10, 2006 16:45
