Home > Forums > OpenFOAM Running, Solving & CFD
simpleFoam with pumped outlet, will this work?
Old   March 12, 2013, 21:41
Default simpleFoam with pumped outlet, will this work?
Debb
tellico is on a distinguished road
I am trying to run a basic simulation using simpleFoam where water flows into a tank and is "sucked out" a vertical pipe that starts just above the floor of the tank and is attached to a pump above the tank
I am specifying inlet velocity, and a pressure and velocity at the base of the vertical pipe (within the tank), and leaving the pressure at the actual outlet of the pipe (which terminates above the tank) as zeroGradient, I am also specifying a pRef value for a cell at the base of the tank, my pRefValue is the water column at said cell.
I'm getting semi-believable results, and I'm wondering if this is just a fluke or if I'm doing this right.
good karma to anyone who can help
tellico is offline   Reply With Quote
Old   March 13, 2013, 02:50
HECKMANN Frédéric
fredo490 is on a distinguished road
If you post your case it would be much easier for us to help you. The mistakes are often in the details
You can attach a zip file to your answer or share a link (dropbox, ...)
fredo490 is offline   Reply With Quote
Old   March 13, 2013, 09:10
Debb
I've uploaded my files to dropbox.
https://www.dropbox.com/sh/zznhn1w7ecp4sdn/-DEKH7K99v
Old   March 20, 2013, 10:46
Debb
I ended up finding some major issues with my mesh, which have now been corrected.
I'm still having issues with my boundary conditions.
Water is entering the tank from the large horizontal pipe and would be drawn out from the vertical pipe in the corner of the tank (this is a pump suction line).
my BCs are as follows:
U:
inlet
fixedValue uniform (10.5 0 0)
outlet
pressureInletOutletVelocity uniform (0 0 1)
walls
fixedValue uniform (0 0 0)
P:
inlet
zeroGradient
outlet
totalPressure uniform 0
With this I get a "believable" flow entering the tank but the flow wont go up through the outlet pipe. I am specifying the face of the top of the outlet pipe as my outlet.
Thread Tools
Trackbacks are On
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 11 January 5, 2013 07:21
Trying to run a benchmark case with simpleFoam spsb OpenFOAM 3 February 24, 2012 10:07
Inlet but not outlet mireis FLUENT 1 June 10, 2010 10:56
B.C.S on outflow outlet and pressure outlet kenneth Main CFD Forum 4 May 29, 2008 20:57
