-   -   parallel computing doesn't speed up (http://www.cfd-online.com/Forums/openfoam-solving/114680-parallel-computing-doesnt-speed-up.html)
najunaju March 15, 2013 09:10
dear fomers,
greetings!
I am running kepsilon model using pisofoam on bluff body with 2D simulation in a Intel core 2 quad processor with 8gb ram. I have four local processors and the simulation is too heavy that to complete 1 iteration it takes 25 seconds. now,
1. if I decompose into 2 or 4 processors (like, 2 1 1 or 2 2 1) the speed is same. doesn't change at all.
2. another surprising thing is, if I decompose into 6 or 8 processors and run through mpi commad, it runs but the speed is same though I have 4 processors. how come it runs in 6 or 8 processors?
I have to have around 1223987 interations which would take 10 to 15 days if I can't use parallel computing effectively.
please help me, please. I will be waiting.
Hiroshiman March 15, 2013 11:35
Hi !
A few questions :
What is the size of your domain ?
What was the exact command you used to run your case ? I used to forget the -parallel parameter at first.
najunaju March 16, 2013 01:43
thank u hiroshiman for ur inquiry.
my domain is 41Dx25D and width is extruded by openfoam, in the width direction there are single cell. I have total 6,00,000 cells to maintain y plus around 1 to 3. D is the height of domain.
I used simple dicomposition with the following command,
mpirun -np 4 pisoFoam -parallel
please help me, if u can. I am running out of time.
Hiroshiman March 18, 2013 10:55
with 6E6 cells, the problem should be large enough to be run over a few cpus.
Could you post the output of the solver on the few few first iterations to have a better idea of what's happening ?
najunaju March 21, 2013 04:39
Dear Hiroshiman,
Thank you for your query. I have reduced mesh number and running now, I think this allowable for me.
Thank you again.
