Santiago |
March 15, 2013 23:27 |
GAMG and AMI: HELP!
Hi Guys!
So I've been trying to run a case using the GAMG solver
and at the same time i have several AMI interfaces over my domain.
When I send the case, this is what I get:
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.1-221db2718bbb
Exec : potentialFoam -noFunctionObjects
Date : Mar 15 2013
Time : 23:15:27
Host : "sc.iihr.uiowa.edu"
PID : 27996
Case : /home/slopezcastano/porousE4_1
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
AMI: Creating addressing and weights between 7242 source faces and 8262 target faces
AMI: Patch source weights min/max/average = 0.664996, 1.00091, 0.999799
AMI: Patch target weights min/max/average = 0.867808, 1.00285, 1
Calculating potential flow
--> FOAM FATAL ERROR:
Size mismatch.
Source patch size:3621
Source agglomeration size:1820
Target patch size:4131
Target agglomeration size:2073
From function AMIInterpolation<SourcePatch, TargetPatch>::AMIInterpolation
const AMIInterpolation<SourcePatch, TargetPatch>&,
const label,
const labelList&
in file lnInclude/AMIInterpolation.C at line 1622.
FOAM exiting
I assume is some kind of problem with the GAMG solver since
I sent the simulation using PBiCG and is running fine. If somebody
could give me a hint about this problem I'd greatly appreciate it.
Regards,
Santiago
