boussineSimpleFoam, inlet/outlet and timestep errors - humanbody case
Like Tree1Likes
  • 1 Post By jherb
Old   August 12, 2014, 09:55
Default boussineSimpleFoam, inlet/outlet and timestep errors - humanbody case
Gowain
eaglemckenna is on a distinguished road
Hi
apologies for the length of this post but I need to make sure I get answers and the questions are understood properly. I am using boussinesqSimpleFoam solver for a human body with 100watts heatflux in a cube domain with inlet and outlet points overhead. Firstly, I have been having issues assigning appropriate inlet and outlet boundary conditions, inlet 0.4m/s – I have managed to get results for when 0/U inlet patch is fixed value and 0/U outlet patch is zerogradient and 0/p inlet is zeroGradient and 0/p outlet is calculated – however because of the zeroGradient bc as the solution continues the velocity at outlet reaches an unrealistic value, I am trying to replicate overhead and air conditioning
So, what inlet and outlet conditions do I need to have , I have tried to use flowRateVelocityInlet as well as inletOutlet but am unsure how to properly impose them.
I also expexted to see a thermal plume but one is not present...
Also my timestep errors seem to be growing – which is a concern – again I believe this to be due to the improper inlet and outlet boundary conditions
please see attached for some better understanding
also 0 file: https://copy.com/jMC3ORxH3RWK
thank a lot
g
eaglemckenna is offline   Reply With Quote
Old   August 13, 2014, 06:00
Joachim Herb
jherb is on a distinguished road
For the use of inletOutlet boundary condition have a look for the tutorial in incompressible/pimpleFoam/TJunction
If you are looking for a tutorial with a special boundary condition use these commands:
cd $FOAM_TUTORIALS/
find . -type f | grep -E "/0.*/" | xargs grep "inletOutlet" | less
eaglemckenna likes this.
jherb is offline   Reply With Quote
Is there a tool to reset case or delete the timestep folders of previous running? funature OpenFOAM Running, Solving & CFD 5 September 23, 2013 09:24
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
simpleFoam errors... timestep continuity error/Floating point exception headwing OpenFOAM 1 January 15, 2011 04:04
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
Why timestep for steady state case? Srikanth Main CFD Forum 4 September 19, 2007 06:26
