[swak4Foam] is it possible and correct to set a logical condition in variables of groovyBC?
Old   March 17, 2013, 19:21
Default is it possible and correct to set a logical condition in variables of groovyBC?
immortality's Avatar
Ehsan
immortality is on a distinguished road
like "a=t1<=time()<t1+deltaT;"
And then use a in expressions?
immortality is offline   Reply With Quote
Old   March 18, 2013, 06:49
Assistant Moderator
Bernhard Gschaider
Not sure. There might be a bug there in groovyBC. But your expression won't work anyway.
a) deltaT is a function (write deltaT())
b) checking ranges like this won't work you've got to split it into two comparisons "t1<=time() && time()<(t1+deltaT())". What you're doing only works in C++ itself and there it wouldn't give the result you're expecting: first you compare t1 and time() which is either true or false. C++ interprets these as either 1 or 0 and compares these numbers with t1+deltaT()
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   August 26, 2016, 03:44
DavidTran
davidtran is on a distinguished road
Hi Ehsan,
Did you solve your problem? Could you share your solution?
Thank you.
davidtran is offline   Reply With Quote
Old   September 15, 2016, 03:00
Paritosh Vasava
vasava will become famous soon enough
I am trying something similar with help from these pages.
I will post if I get something going.
vasava is offline   Reply With Quote
Old   September 15, 2016, 05:28
Paritosh Vasava
I wanted to have a boundary condition that follows a function up to a time and then use a constant value:
f(x) = F+101325; when t<0.0012
and
f(x) = 101325; when t>0.0012
Here is what I used (and it worked):
    inlet
        type            groovyBC;
        value           uniform 101325;
        variables 	(
			"tPositive=0.0012;"
			"factor=(time()>tPositive) ? 0 : 1;"
			"inPress=SOME FUNCTION;"
        valueExpression "(inPress*factor)+101325";"
I have not seen any groovyBC where deltaT is used.
Old   September 15, 2016, 14:56
Assistant Moderator
Bernhard Gschaider
and
    inlet
        type            groovyBC;
        variables     (
            "tPositive=0.0012;"
You usually don't need that. Boundary condition should model the physics. deltaT() is a property of the discretization. If you're using that in a physical expression you're in trouble (there are applications for that function. Usually involving integration)
