torque is 5 times more than expected why?
Old   February 19, 2013, 01:06
Default torque is 5 times more than expected why?
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
Hi Foamers,
I am working on axial flow fan, I want to calculate the torque.
I am using the function, which is posted by linnenman.
The problem is I am always getting 5 times bigger values.
for the whole fan (8 blades) the torque is 72N-m,
since I am using quarter of the section the torque should be 18 N-m, but I am always getting above 80N-m.
The same way in fluent 10 times bigger value(170 N-m), that means I am doing something wrong in the settings, but I am not able to figure out that.
can you people give me some small hint, what could be the possible mistake?
I am running out of Idea.
any sort of idea or hint will be appreciated.
Thanks,
Sivakumar
sivakumar is offline   Reply With Quote
Old   February 24, 2013, 17:26
Default Default torque is 5 times more than expected why?
jmf
Jean-Michel FONTAINE
jmf is on a distinguished road
Hi
Please could you tell more about your case ?
Which solver ?
What are your boundaries ?
How is your mesh ?
Wishes
Jean-Michel
jmf is offline   Reply With Quote
Old   February 25, 2013, 04:47
sivakumar selvaraju
Hi Jean-Michel,
Thanks for your reply, I am using MRFSimpleFoam and SRFSimpleFoam.
I got the information how to calculate torque from the output. I think in openFoam the problem is fixed. I am getting reasonable torque as I expected, but the pressure raise is 15% error.
But in fluent, I am using SRF Solver. I dont know how to read the torque out put
results --> Reports --> moment --> rotation axis (0 0 0) & moment (0 0 1)
I am bit confused now the out put is for the existing geometry (2blade) or for the whole Geometry (8Blades), I am using only 1/4 th of the geometry for the simulation.
the fluent out put is something like this (11.5 12.5 -78).
I have uploaded my openFoam case in sendspace, if you have some spare time please have a look and give me your commands.
http://www.sendspace.com/file/ywba19
Thanks for you time,
Sivakumar
Old   March 13, 2013, 10:08
sivakumar selvaraju
I found the answer for my question,
The answer is my blade angle, it was wrong.
Now I have changed it and I got the perfect results.
Thanks,
Sivakumar
Old   March 20, 2013, 06:57
Sam
sam181087 is on a distinguished road
Hi Sivakumar,
I am also doing the axial fan simulation in CFX and my torque prediction is more as compared to test value.
Can you please tell me about the boundary conditoin.
Thanks,
A.S.
sam181087 is offline   Reply With Quote
Old   March 20, 2013, 09:42
sivakumar selvaraju
Hi Sam,
I am happy to give you the information, I have some questions,
i) how big is your torque?
ii) what is the static pressure raise?
if you are getting more torque and less static pressure raise, then you have problem with your blade angle. I will strongly suggest you to check the stagger angle.
Regarding BC's fan, hub and shroud --> wall, inlet --> mass flow rate, outlet --> Pressure outlet (0Pa) remaining all periodic (1/8th of the fan passage).
Thanks,
Sivakumar
Old   March 22, 2013, 13:56
Sam
Hi Sivakumar,
Thanks for your reply.
1) Fan considered is ceiling fan and predicted torque value is 40-60% higher than test value.
2) RPM of fan is the only input, so mass flow rate cant be given as input.
So, can you help with this.
Thanks&Regards,
Sam
Old   March 23, 2013, 04:19
sivakumar selvaraju
Hi Sam,
I am not clear about your question, what are the boundary conditions your using at present (inlet and outlet)? how your case look like?
can you post some picture of your case, it may give some idea to the people those who want to help you.
It is difficult to give an idea with out seeing your case, try to post your mesh in cfx forum, some cfx experts can help you.
Thanks,
Sivakumar
Old   March 23, 2013, 10:15
Sam
hi,
1) Its a simple case of ceiling fan rotating in a room at constant RPM.
2) So in rotating domain which contains whole fan and other is stationary domain.
The problem is prediction of fan torque.
Can anyone help with this.
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
wmake compiling Problem with OF1.5 openTom OpenFOAM Installation 4 May 3, 2009 14:44
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
