March 26, 2013, 10:54 |
Non-separated flow in rhoCentralFoam
VS
Hey guys,
i simulated the flow of air over a sphere in Re=1.8 million with rhoCentralFoam, where i supposed to be able to see that the flow behind the sphere would be separated, due to the high Reynolds number. Instead, the flow is stays attached to the sphere, no separation. I used ePsi thermo model and similar BCs like the ones in wedges tutorial. Does anyone have any idea what may be the problem? Thanks in advance |
March 26, 2013, 11:41 |
HECKMANN Frédéric
What is your turbulence model ? How are your inlet properties (turbulence level) ?
March 26, 2013, 14:05 |
VS
I used both laminar and turbulent k-omega models. The destributions of all the quantities look fine everywhere, but i don't get any vortices or separation.
March 26, 2013, 14:10 |
HECKMANN Frédéric
Can you post your case files? Put everything except the mesh folder. You can enclose a zip file to the forum ("manage attachment ") .
March 29, 2013, 08:19 |
VS
Sorry for the delay, here are the 0 files for p/T/U
object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e+05; boundaryField { GEOM { type zeroGradient; } FARFIELD { type outletInlet; outletValue uniform 1e+05; value uniform 1e+05; } } object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 273; boundaryField { GEOM { type zeroGradient; } FARFIELD { type inletOutlet; inletValue uniform 273; value uniform 273; } } object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (100 0 0); boundaryField { GEOM { type fixedValue; value uniform (0 0 0); } FARFIELD { type inletOutlet; inletValue uniform (100 0 0); value uniform (100 0 0); } Also,the thermophysical properties : object thermophysicalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>; mixture { specie { nMoles 1; molWeight 28.96; } thermodynamics { Cp 1004.5; Hf 2.544e+06; } transport { mu 1.8e-05; Pr 0.7; } |
attached flow, rhocentralfoam, vortices |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 14:00 |
Different flow patterns in CFX and Fluent | avi@lpsc | CFX | 6 | April 17, 2012 02:22 |
Always crash when solve a C-D nozzle flow field using rhoCentralFoam | hawklion | OpenFOAM | 3 | March 8, 2011 20:03 |
turbulence model for separated flow in diffuser | Martis | STAR-CCM+ | 0 | March 2, 2010 03:08 |
CFL limits for separated flow | Bigarella | Main CFD Forum | 3 | August 11, 2002 08:22 |
