If OpenFOAM can run different solver in different domain in the same time ? |
February 17, 2010, 03:57 |
Jiang
Rep Power: 16 |
Dear all,
I want to know If OpenFOAM can run different solver in different domain in the same time . for example: In the left domain, I want to use pisoFoam to generate turbelence, while in the right domain, I want to use buoyantBoussinesqPisoFoam. Is it possible in Foam ? and how can I do this ? I think this is an interesting problem. |
April 10, 2014, 04:17 |
Hi All,
This is almost the same thing i am also asking, In a particular domain, I want to solve for heat transfer in the fluid at initial stage, as the flow passes to middle domain i have to solve for heat transfer as well as magnetic field while in the end of the domain i have to solve the combination of electric-magnetic and thermal effect. This all is to be done in the same structure at different location for e.g., consider a pipe of 1 m. length then for first 30 cm i have to solve for heat transfer after leaving 5 mm gap again for next 30 cm and so on, as explained above. It would be great help!!! Thanks and Regards, Adarsh R. Tiwari |
May 15, 2014, 04:27 |
Olivier
Rep Power: 17 |
hello,
Take a look at chtMultiRegionFoam. There is fluid and solid region, but you can add other region (porous, mhd, ...) or modify fluid/solid region. But you need to do some coding to do that. regards, olivier |
Display Modes | |
Suggested unsteady, implicit solver stable with arbitrarily large time steps | djbungee | OpenFOAM Programming & Development | 45 | March 23, 2015 04:14 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
Modifying gravity vector and MRFomega a run time | nico765 | OpenFOAM Running, Solving & CFD | 3 | December 22, 2007 10:41 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
