Pressure singularities using OF
1 Attachment(s)
I was wondering whether anyone might know what is going on in my model below. The graphic shows the suction surface of a turbine blade towards the trailing edge. As you can see, i get these 'hot spots' of high and lower pressure forming about ~80 iterations into the simulation. I am using SRFSimpleFoam and solving for turbulence using kOmegaSST, which i think is set up correctly ... I am using the SmoothSolver for Urel / k / omega etc and GAMG for pressure ... I have checked the mesh and can't see any issues with that - checkMesh and mesh metrics in ICEM all seem ok. The mesh also solves well (ok) in Fluent, so i was wondering whether anyone had any ideas or had seen something like this before. Many thanks in advance regards jonathan EDIT: PS Forgot to mention, the job runs 'fine' using a single thread, but throw a seg fault when i try to split it over several threads??? I dont haven't had any issue running other jobs in parallel so this is also a bit strange. Any ideas ?? thanks again |
