"Counter-gradient" term in interFoam.
Old   September 11, 2013, 21:42
Default "Counter-gradient" term in interFoam.
Dongyue Li
sharonyue is on a distinguished road
Hi guys,
Some articles depict the interFoam in detail, but I still have many confusions. In weller's paper: he said:
\frac{{\partial \alpha }}{{\partial t}} + \nabla  \cdot \alpha u + \nabla  \cdot \left( {\alpha \left( {1 - \alpha } \right){u_c}} \right) = 0
U_c ensures compression. In order to ensure the compression term does not bias the solution in anyway it should only introduce flow of alpha normal to the interface, in the direction:\frac{{\nabla \alpha }}{{\left| {\nabla \alpha } \right|}}
These considerations suggest a model for Uc of the form
{U_c} = {c_\alpha }\left| U \right|\frac{{\nabla \alpha }}{{\left| {\nabla \alpha } \right|}}
So according to Weller's thought, U_c is constructed by a guess.
but in another paper. it said:
U_c=U_l - U_g
All in all, how can we ensure these two U_c are the same?
sharonyue is offline   Reply With Quote
Old   September 12, 2013, 01:51
Bernhard
Bernhard is on a distinguished road
The first one is the one that is implemented in OpenFOAM, as you can easily confirm from alphaEqn.H.
The second one does not have a meaning from a simulation point of view, as there is only one U in the simulations. You don't keep track of both liquid and gas velocity, as you would do in twoPhaseEulerFoam. However, if you would use indicator functions for that set of equation, you will eventually find U_c=U_l-U_g.
Also, be aware that this is not a counter-gradient term, but more of a convective like term, with the same purpose in the end.
Bernhard is offline   Reply With Quote
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
InterFoam: add a source term in alpha eq. Alucard OpenFOAM Programming & Development 12 November 5, 2017 19:16
Add source term in alphaEqn.H of interFoam tayo OpenFOAM 1 October 23, 2013 03:40
Adding a new term in momentum equation of Interfoam udiitm OpenFOAM 5 July 29, 2012 10:52
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
