Boundary condition in a multiphase flow
Old   April 2, 2013, 04:46
Default Boundary condition in a multiphase flow
giack is on a distinguished road
Hi to all,
I have a problem in the setting of the boundary condition of a multiphase flow using interfoam.
My case is summarized as follow:
at the initial time t=0 the right wall of a closed tube completely filled with a liquid is removed, allowing the liquid to exit the domain and, at the same time, allowing the gas to enter.
I set this boundary condition:
U) fixedValue (0,0,0) in the pipe wall and in the left inlet, zeroGradient in the outlet
p) zeroGradient in the pipe wall and in the left inlet, fixedValue of 1 atm in the outlet
alpha) zeroGradient in the pipe wall. For the left inlet and the outlet I tried some case:
- InletOutlet/InletOutlet
- zeroGradient/zeroGradient
- zeroGradient/InletOutlet
- zeroGradient/calculated
but all this case give me strange solution
Someone have an idea to set the boundary condition for this case?
thank to all
giack is offline   Reply With Quote
alpha1, boundary condition, interfoam, multi phase
Outlet boundary condition for a heated tube flow JinBiao OpenFOAM Running, Solving & CFD 0 July 28, 2012 03:56
flow in duct-fixed pressure boundary condition sepidehkavousi Main CFD Forum 9 May 20, 2012 12:11
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 18:36
outflow boundary condition for multiphase flow deepak FLUENT 1 June 21, 2007 08:23
