VAWT using AMI very high courant number or very small time step
Old   April 1, 2013, 15:41
Default VAWT using AMI very high courant number or very small time step
Julio Silveira
biau is on a distinguished road
Dear all,
I am trying to set up a simulation for a VAWT in OpenFOAM. I can simulate it well in fluent,but I need more computational power. I am currently trying to use OpenFoam in order to be able to use a cluster. At the moment I am trying to simulate a 2D VAWT inside a wind tunnel, so later i can do a 3D in a much more refined mesh.
My OpenFoam version is 2.1.1
I am currently trying a laminar case using cyclicAMI for my sliding interfaces. But after few times steps, the courant number start to go very very high and then the simulation crashes. If i limit the courant number, it will adjust the time step for something very very small which would take forever to compute.
Any help would be appreciated.
Thank you
case file in following link:
https://www.dropbox.com/sh/bg0kos6qrg6jufq/om0HkZSmtn
biau is offline   Reply With Quote
Old   April 2, 2013, 06:45
Håkon Bartnes Line
hakonbar is on a distinguished road
Did you remember to split the baffles between the two cell zones?
I think the command is "createOrSplitBaffles -split -overwrite", but you can find it in the file called "Allrun.pre" in the pimpleDyMFoam/propeller tutorial.
hakonbar is offline   Reply With Quote
Old   April 2, 2013, 09:13
Default simulation
Julio Silveira
it seemed to help. Lets see how it goes.
Thank you
ami, openfoam, vawt
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
Very high courant number, time step continuity errors and bounding epsilon erncyc OpenFOAM Running, Solving & CFD 1 March 24, 2011 11:00
