-   -   TSG case by using TransientSimpleDyMFoam (http://www.cfd-online.com/Forums/openfoam-solving/115567-tsg-case-using-transientsimpledymfoam.html)
renyun0511 April 2, 2013 11:02
Hi all,
Recently, I have been studying the unsteady simulation of pumps by using OpenFOAM. Then, I try to simulate the Timisoara swirl generator case with transientSimpleDyMFoam solver firstly. The solver and case are both downloaded from the webpage: http://openfoamwiki.net/index.php/Sig_Turbomachinery_/_Timisoara_Swirl_Generator
But, the case was diverged after several steps, and the log file is in the attached files. I don't know why it was diverged though I haven't changed anything? Would someone like to help me? I will appreciate it!
here is the setup of fvSolution and controdict:
fvSolution file:
solvers
p PCG
preconditioner DIC;
tolerance 1e-05;
relTol 0.002;
minIter 2;
maxIter 140;
pFinal PCG
preconditioner DIC;
tolerance 1e-05;
relTol 0.001;
minIter 2;
maxIter 280;
pcorr PCG
preconditioner DIC;
tolerance 1e-05;
relTol 0.001;
minIter 2;
maxIter 180;
U PBiCG
preconditioner
{ type DILU;}
smoother
{ type DILU; }
minIter 1;
maxIter 4;
tolerance 1e-07;
relTol 0;
k PBiCG
preconditioner
{ type DILU; }
smoother
{ type DILU; }
minIter 1;
maxIter 3;
tolerance 1e-07;
relTol 0;
epsilon PBiCG
preconditioner
{ type DILU; }
smoother
{ type DILU; }
minIter 1;
maxIter 3;
tolerance 1e-07;
relTol 0;
omega PBiCG
preconditioner
{ type DILU; }
smoother
{ type DILU; }
minIter 1;
maxIter 3;
tolerance 1e-07;
relTol 0;
PISO
nCorrectors 0;
nOuterCorrectors 10;
nNonOrthogonalCorrectors 0;
correctPhi false;
relaxationFactors
p 0.3;
U 0.75;
k 0.5;
epsilon 0.5;
omega 0.5;
Controdict file:
Best Regards,
Yun Ren
deepsterblue April 2, 2013 15:46
You may want to switch off the relative tolerances in the pressure solver.
renyun0511 April 2, 2013 22:34
Hi Sandeep,
What do you mean about switch off the relative tolerances in the pressure solver. Sorry, I can't understand. Could I have some more details, please. And I just sent an email to you. Hoping for your reply. Thank you very much!
Regard,
Yun Ren
deepsterblue April 3, 2013 08:55
Sorry for being cryptic. Set relTol to 0.0 for pressure in fvSolution.
