User defined time-varying volVectorField as input for scalarTransportFoam
Old   October 30, 2013, 17:03
Default User defined time-varying volVectorField as input for scalarTransportFoam
Vishal Achasrya
vishalsacharya is on a distinguished road
If I wanted to solve a scalarTransport with time-varying velocity field that is input by the user and not really solved for, then what is the best way to do this?
The input velocity field could be of the form u_x = A + B * cos (t) where A, B are constants and t is time.
My next question is, if I create time-folders in my case directory and generate the U file for each of those time-directories based on my time-varying function, and then put the U block and "createPhi" section from the createFields file into the loop in the main code, can I then get scalarTransportFoam to use a time-varying velocity field? Im assuming that since the reading of U is in the loop, it would read the time-folder in every time-step for the U file instead it and use the data in that?
Thanks
vishalsacharya is offline   Reply With Quote
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Time averaged fields on a defined time range Yann OpenFOAM Post-Processing 8 August 7, 2019 04:46
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
User code, How can I get information from last time step onlyacan STAR-CCM+ 1 July 24, 2012 13:52
