-   -   solving problem (http://www.cfd-online.com/Forums/openfoam-solving/115712-solving-problem.html)
Ingenieur April 5, 2013 06:03
solving problem
Hi Foamers,
could any one plz help me to find the Error with simuation car in windtunnel,
i got this error by solving with LESmodel.
the mesh was correctly created, but i dont know the backgound of this error:
--> FOAM FATAL IO ERROR:
keyword surface is undefined in dictionary "::surfaces::surfaces"
file: ::surfaces::surfaces from line 194 to line 200.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 410.
FOAM exiting
i'll be grateful for ur help
thanx in advance,
Monzer
Tushar@cfd April 5, 2013 07:26
Originally Posted by Ingenieur (Post 418515)
Hi Foamers,
FOAM exiting
thanx in advance,
Monzer
what are the mesh geometry and the boundary conditions for your case?? :)
Ingenieur April 5, 2013 08:24
Hi Tushar,
my autoHexMesh ist:
FoamFile
version 2.1.2;
format ascii;
root "";
case "project2";
instance "";
local "";
class dictionary;
object autoHexMeshDict;
include "$FOAM_CONFIG/autoHexMesh.misc";
include "$FOAM_CONFIG/autoHexMesh.motionDict";
include "$FOAM_CONFIG/autoHexMesh.snapDict";
include "$FOAM_CONFIG/autoHexMesh.shrinkDict";
globalFeatureEdges true;
doLayers true;
doSnap true;
doRefine true;
curvature 0.95;
nBufferLayers 4;
keepPoints ((0 0 0));
surfaces
name SAE;
file "SAE.stl";
surfaceLayers 3;
maxRefinementLevel 5;
minRefinementLevel 3;
regions
surfaceLayers 3;
name Default_PSHELL_Property;
surfaceLayers 3;
name Default_PSHELL_Property1;
surfaceLayers 3;
name Default_PSHELL_Property2;
surfaceLayers 3;
name Default_PSHELL_Property3;
surfaceLayers 3;
name Default_PSHELL_Property4;
surfaceLayers 3;
name Default_PSHELL_Property5;
name Windkanal;
file "Windkanal.stl";
surfaceLayers 0;
maxRefinementLevel 0;
minRefinementLevel 0;
regions
surfaceLayers 0;
name 00_Inlet;
surfaceLayers 0;
name 00_Outlet;
surfaceLayers 3;
name 00_Ground;
surfaceLayers 0;
name 00_TOP;
surfaceLayers 0;
name Right_Side;
surfaceLayers 0;
name 00_Left_Side;
refinementShells
name VR;
type searchableBox;
min (-1500 -1500 -202);
max (3500 1500 1500);
refineInside true;
level 3;
and the boundary is:
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
6
block-mesh_BMMinX
type wall;
nFaces 7936;
startFace 2684744;
block-mesh_BMMaxX
type wall;
nFaces 7936;
startFace 2692680;
block-mesh_BMMinZ
type wall;
nFaces 14136;
startFace 2700616;
block-mesh_BMMaxZ
type wall;
nFaces 14136;
startFace 2714752;
block-mesh_BMMinY
type wall;
nFaces 7296;
startFace 2728888;
block-mesh_BMMaxY
type wall;
nFaces 7296;
startFace 2736184;
the blockMesh is:
FoamFile
version 2.1.2;
format ascii;
root "Y:/10_Studenten/UnsteadyAero/OpenFOAM_Validierung/Testing";
case "project2";
instance "";
local "";
class dictionary;
object blockMeshDict;
convertToMeters 1;
edges ();
mergePatchPairs() ;
vertices
(-26000 -31000 -1202)
(31000 -31000 -1202)
(31000 31000 -1202)
(-26000 31000 -1202)
(-26000 -31000 31000)
(31000 -31000 31000)
(31000 31000 31000)
(-26000 31000 31000)
blocks
hex
0
1
2
3
4
5
6
7
(114 124 64 )
simpleGrading
(1 1 1)
patches
wall
block-mesh_BMMinX
( (0 4 7 3 ) )
wall
block-mesh_BMMaxX
( (1 2 6 5 ) )
wall
block-mesh_BMMinZ
( (0 3 2 1 ) )
wall
block-mesh_BMMaxZ
( (4 5 6 7 ) )
wall
block-mesh_BMMinY
( (0 1 5 4 ) )
wall
block-mesh_BMMaxY
( (3 7 6 2 ) )
Ingenieur April 5, 2013 08:33
the boundary conditions are :
boundaryConditions
regionDefaults
walls
outlets
inlets
partialNamed
exactNamed
Windkanal_00_Ground
U
value uniform (80 0 0);
type fixedValue;
Windkanal_00_Inlet
U
type fixedValue;
nuTilda
type turbulentIL;
I 0.1;
L 0.01;
Uref 80;
Windkanal_00_Left_Side
nuSgs
type zeroGradient;
U
type slip;
Windkanal_00_Outlet
p
value uniform 0;
type fixedValue;
nuTilda
type turbulentIL;
I 0.1;
L 0.01;
Uref 80;
Windkanal_00_TOP
nuSgs
type zeroGradient;
U
type slip;
Windkanal_Right_Side
nuSgs
type zeroGradient;
U
type slip;
Tushar@cfd April 7, 2013 05:09
boundaryConditions
regionDefaults
walls
outlets
inlets
partialNamed
exactNamed
Windkanal_00_Ground
U
type fixedValue;
Windkanal_00_Inlet
U
type fixedValue;
nuTilda
type turbulentIL;
I 0.1;
L 0.01;
Uref 80;
nuSgs
type zeroGradient;
U
type slip;
Windkanal_00_Outlet
p
value uniform 0;
type fixedValue;
nuTilda
type turbulentIL;
I 0.1;
L 0.01;
Uref 80;
Windkanal_00_TOP
nuSgs
type zeroGradient;
U
type slip;
nuSgs
type zeroGradient;
U
type slip;
Can you please upload your case file for reference? That would be much better. :)
Tushar@cfd April 10, 2013 06:06
boundaryConditions
regionDefaults
walls
outlets
inlets
partialNamed
exactNamed
Windkanal_00_Ground
U
type fixedValue;
Windkanal_00_Inlet
U
type fixedValue;
nuTilda
type turbulentIL;
I 0.1;
L 0.01;
Uref 80;
nuSgs
type zeroGradient;
U
type slip;
Windkanal_00_Outlet
p
value uniform 0;
type fixedValue;
nuTilda
type turbulentIL;
I 0.1;
L 0.01;
Uref 80;
Windkanal_00_TOP
nuSgs
type zeroGradient;
U
type slip;
nuSgs
type zeroGradient;
U
type slip;
You do check your blockMesh file, I think there you are mistaking.
Try to find the inlet/outlet patches and wall patch, and try to co-relate the code with boundary conditions.
Tushar@cfd April 10, 2013 06:16
Originally Posted by Ingenieur (Post 418537)
Hi Tushar,
FoamFile
version 2.0;
format ascii;
object boundary;
6
block-mesh_BMMinX
type wall;
nFaces 7936;
startFace 2684744;
block-mesh_BMMaxX
type wall;
nFaces 7936;
startFace 2692680;
block-mesh_BMMinZ
type wall;
nFaces 14136;
startFace 2700616;
block-mesh_BMMaxZ
type wall;
nFaces 14136;
startFace 2714752;
block-mesh_BMMinY
type wall;
nFaces 7296;
startFace 2728888;
block-mesh_BMMaxY
type wall;
nFaces 7296;
startFace 2736184;
the blockMesh is:
FoamFile
version 2.1.2;
format ascii;
case "project2";
instance "";
local "";
class dictionary;
convertToMeters 1;
edges ();
mergePatchPairs() ;
vertices
(31000 31000 -1202)
(31000 31000 31000)
blocks
hex
0
1
2
3
4
5
6
7
(114 124 64 )
simpleGrading
(1 1 1)
patches
wall
block-mesh_BMMinX
( (0 4 7 3 ) )
wall
block-mesh_BMMaxX
( (1 2 6 5 ) )
wall
block-mesh_BMMinZ
( (0 3 2 1 ) )
wall
block-mesh_BMMaxZ
( (4 5 6 7 ) )
wall
block-mesh_BMMinY
( (0 1 5 4 ) )
wall
block-mesh_BMMaxY
( (3 7 6 2 ) )
I mean to say in my earlier thread, that you need to change the above code lines which you have written..
Best of luck..
