-   -   PIMPLE algorithm relaxation Factors (http://www.cfd-online.com/Forums/openfoam-solving/115744-pimple-algorithm-relaxation-factors.html)
Mojtaba.a April 5, 2013 14:45
Hi guys.
I am using pimpleFoam for my case and I noticed that there are two keywords defined for relaxationFactors in fvsolution. fields and equations.
relaxationFactors
fields
equations
"U.*" 0.9;
"k.*" 0.7;
"epsilon.*" 0.7;
What are the differences between these two? there is no such a thing in SIMPLE algorithm.
Bests
fumiya April 6, 2013 00:31
Hi Mojtaba,
You can also find the keywords defined in the tutorials of simpleFoam.
Regarding your questions, you might want to read the Ph.D. thesis of Dr. Jasak:
http://www.h.jasak.dial.pipex.com/
especially
  • keyword "equations": eq. (3.95) and (3.96) on page 115
  • keyword "fields": eq. (3.145) on page 149
Hope this helps,
Fumiya
Mojtaba.a April 6, 2013 04:55
Originally Posted by fumiya (Post 418691)
Hi Mojtaba,
especially
Hope this helps,
Fumiya
Thank you Fumiya,
as I could get,
  • under-relaxation factors which are placed in keyword "equations" are the general factors which are used to under relax the system of algebraic equations created by the discretisation.
  • under-relaxation factors which are placed in keyword "fields" are used to under relax new pressure equations. as in Dr.Jasak Thesis:
In order to obtain a better approximation of the “correct” pressure field, it would be necessary to solve the pressure equation again
therefore another relaxation factors for p and U are defined.
So for instance is it ok to say:
relaxationFactors
fields
U 0.7
p 0.3
equations
"U.*" 0.9;
"k.*" 0.7;
"epsilon.*" 0.7;
Bests.
fumiya April 6, 2013 07:26
Hi Mojtaba,
I think you understand correctly.
relaxationFactors
fields
U 0.7;
p 0.3;
equations
"U.*" 0.9;
"k.*" 0.7;
"epsilon.*" 0.7;
I think you should put U 0.7; in the equations dictionary, because the variable U is solved in UEqn.
Hope this helps,
Fumiya
Mojtaba.a April 6, 2013 15:47
Yes you are right. I thought there is an another relaxation factor envolved in new pressure equation, but there is not.
p^{new}=p^{old}+\alpha_{p}*(p^p-p^{old})
