Home > Forums > OpenFOAM Running, Solving & CFD
BC for outlet - interFoam
Like Tree3Likes
  • 2 Post By vainilreb
  • 1 Post By vainilreb
Old   April 9, 2013, 09:34
Question BC for outlet - interFoam
Pedro Ramos
pedroxramos is on a distinguished road
Hello!
I'm doing the flow simulation around a cylinder but this happens:
http://www.cfd-online.com/Forums/att...m-picture1.jpg
I'm thinking that the problem ins the boundary condition on "outlet".
What you suggest?
Best regards.
pedroxramos is offline   Reply With Quote
Old   April 9, 2013, 09:40
Robert
vainilreb is on a distinguished road
1. What do we see on this picture? I guess it's alpha?
2. Where's the cylinder located?
3. Could you please post your BC files?
Thanks,
Robert
vainilreb is offline   Reply With Quote
Old   April 9, 2013, 09:49
Pedro Ramos
Hi Robert!
See this video and you will understand:
https://dl.dropbox.com/u/22662045/8abril2.avi
Please, take a look on my files:
https://dl.dropbox.com/u/22662045/pier8abril2.rar
Old   April 9, 2013, 10:46
Robert
my first guess is that you should change your pressure BC. I'ts right to fix p_rgh to zero, but doing the same with p, which is p_rgh + rho*H*g won't work. I would give "phaseHydrostaticPressure" a try.
Best, Robert
Old   April 9, 2013, 11:01
Pedro Ramos
Thanks. I'm sorry but I'm new in openfoam, so i didn't understand clearly what you suggest.
"phaseHydrostaticPressure" is a BC?
should I change p for all patches or only in outlet?
Old   April 9, 2013, 11:18
Robert
Oh, right. Sorry!
phaseHydrostaticPressure is a BC for pressure.
Try this for p --> outlet
type phaseHydrostaticPressure;
phaseName alpha1;
rho none;
pRefValue 0;
pRefPoint (0 0 0); // fill in z-coordinate of the water surface for z
value uniform 0;
I hope this helps. Please report.
Tobi and pedroxramos like this.
Old   April 9, 2013, 12:14
Pedro Ramos
thank you so much for your help. unfortunately, it dind't work. see for yourself: https://dl.dropbox.com/u/22662045/pier9april2.avi
the video is short but it seems that the problem is already there.
please, can you help me? i am with this problem for weeks....
thanks
Old   April 9, 2013, 14:43
Robert
Hey,
I've had a closer look at your video and now I've realized that the graph in the lower right corner shows the plot of the values along the flow direction.
You see that the pressure is high at the inlet and drops to zero at the outlet, because you fixed it to zero.
Have you tried to set the BC for U at the outlet to "zeroGradient"?
I'll try some things tomorrow on my workstation, there's no OpenFOAM available here right now. But zeroGradient might already fix this.
Best regards,
Robert
pedroxramos likes this.
Old   April 10, 2013, 06:03
Pedro Ramos
It didn't work again :/ Video is here: https://dl.dropbox.com/u/22662045/pier9abril3.avi
And if the problem isn't in the outlet BC?
The files are here: https://dl.dropbox.com/u/22662045/pier9abril3.rar
I appreciate a little help!
Old   April 16, 2013, 10:25
Pedro Ramos
Hello again... it didn'w work... i'm working in this for weeks...it will turning me crazy!
Thread Tools
Trackbacks are On
InterFoam stops after deltaT goes to 1e14 francesco_b OpenFOAM Running, Solving & CFD 8 July 31, 2013 02:29
Perfect fluid implementation - interFoam Gaetano OpenFOAM Programming & Development 7 January 26, 2013 13:54
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 11 January 5, 2013 07:21
Segmentation fault in interFoam run through openMPI voingiappone OpenFOAM 16 November 2, 2011 07:49
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 21:58
