-   -   Boundary type for patchToPatchInterpolation (http://www.cfd-online.com/Forums/openfoam-solving/116083-boundary-type-patchtopatchinterpolation.html)
Flor April 12, 2013 11:32
Dear Foamers,
I am using of-1.6-ext and I have a question concerning the boundary type for patchToPatchInterpolation:
Which boundary type should I use such that it does not overwrite my interpolated values?
My interpolator looks like this (with patch2dID and patch3dID properly initiated before):
    patchToPatchInterpolation interpolator2d3d
        mesh.boundaryMesh()[patch2dID],
        mesh3d.boundaryMesh()[patch3dID],    // to patch
    intersection::FULL_RAY,
    intersection::VECTOR
And my interpolation is done in the follwoing manner:
    U.boundaryField()[patch3dID] = interpolator2d3d.faceInterpolate <vector>
      U2d.boundaryField()[patch2dID]
    Info << "U2dPatch = " << U2d.boundaryField()[patch2dID] << endl;
    Info << "U3dPatch = " << U.boundaryField()[patch3dID] << endl;
But now I have no clue which type of boundary condition to use. When I use fixedValue, the U.boundaryField()[patch3dID] is overwritten directly, the Info gives the fixed value as output. When I use for instance pressureInletOutletVelocity, the Info outputs the correct value, but it is not used further on. And with calculated I get an error saying that I am probably trying to solve for a default boundary condition.
Any suggestions anyone? Would be highly appreciated!
Thanks in advance
Florian
bigphil April 14, 2013 15:00
Hi Florian,
I presume you are using patchToPatch to explicitly couple two regions?
Therefore, the boundary condition to use will depend on the coupling procedure you would like to use.
For example, in partitioned fluid-structure-interaction models they typically use Dirichlet-Neumann coupling where one of the coupled patches is Dirichlet (fixedValue) and the other coupled patch is Neumann (fixedGradient). So you would patchToPatch transfer the fluid pressure and shear stresses to the solid and then transfer the displacement to the fluid mesh.
So if you give some more information on your model then it might be easier to give advice.
Philip
Flor April 17, 2013 05:30
Hi Philip,
thanks for your reply! You are right, I want to couple two regions explicitly. In one region I solve the Shallow Water Equations, in the other the full Navier-Stokes Equations using interFoam.
Now I want to transfer the velocity values at the outflow of the SWE-region to the inflow of the NSE-region. So only a one-way coupling for a start. Later on I want to do a two-way coupling, which might require an additional iteration procedure, but this will be the next step.
Best regards
Florian
bigphil April 30, 2013 16:25
Originally Posted by Flor
Hi Philip,
I am wondering whether you might have a hint on how to cope with the patchToPatchInterpolation? I am still stuck at the same point that I mentioned in my post in the forum. I only want to transfer the velocities from the 2D-region to the 3D-region, but the fixedValue-BC always overwrites the interpolated values...
Any idea?
Cheers
Florian
Hi Florian,
Can you outline your solution procedure here so I can understand what exactly you are trying to do i.e. solve some equation -> set velocity on BC on some patch -> etc.
Best regards,
Philip
Flor June 3, 2013 13:35
Hi Philip,
sorry for the late reply, there's been quite a lot of other stuff to do plus a short vacation.
My solution procedure is the following:
- First I solve the shallow water equations on region0. This is a pseudo-2d-mesh with a unit height of 1
- Then I want to transfer the resulting velocity vectors from the outlet of region0 to the inlet of region3d.
- On region3d I solve the Navier Stokes Eqs using interFoam. Instead of a fixedValue I want to use the resulting velocities of region0 as Dirichlet-condition at the inlet.
The patchToPatch-interpolator mentioned above seems to work so far, when using it on some test field it performs the interpolation from my 2d-outlet on this test field. But interpolation on the inlet of region3d does not work. When using a fixedValue-bc on the inlet, I guess the const-declaration of the internal values of the patch prevents the interpolation to work. I've been thinking about using const_cast, but this seems to be a bit too rude...
Hope this helps to help :-)
Best regards
Florian
bigphil June 4, 2013 06:18
Originally Posted by Flor (Post 431734)
Hi Philip,
Best regards
Florian
Florian,
OK, when you solve equations in region0 I presume that the outlet boundary condition is a Neumann type (i.e. a fixedGradient of velocity)?
Then you want to take this velocity and set it as a Dirichlet condition (fixedValue of velocity) on the inlet of region3D? This is called Dirichlet-Neumann coupling (used in FSI, contact mechanics, region coupling, ).
Then after solving equations in region3D, do you want to update the gradient on the outlet of region0 based on the gradient on region3D inlet?
I think this should procedure should work, I believe your problems might be due to how you update the boundary conditions.
Something like this should work:
// solve equations in region 0
// then create interpolator
patchToPatchInterpolation outletToInletInterpolate
 mesh.boundaryMesh()[outletPatchIndex],    // from patch
 mesh.boundaryMesh()[inletPatchIndex],    // to patch
 intersection::VISIBLE,
 intersection::CONTACT_SPHERE
// perform interpolation of outlet velocity to inlet patch
vectorField interpolatedInletU = outletToInletInterpolate.faceInterpolate<vector>
U.boundaryField()[outletPatchIndex]
// update inlet velocity boundary condition
// you should probably make sure that the patch is fixedValue
if(U.boundaryField().type() != fixedValueFvPatchVectorField::typeName)
FatalError << "inlet patch should be fixedValue!" << exit(FatalError);
// note that "==" is needed to reset actual boundary condition
// not just change patch values
U.boundaryField()[inletPatchIndex] == interpolatedInletU;
// then solve equation in region3D
// then you can update the gradient on the outlet of region0 if you want
Best regards,
Philip
Flor June 4, 2013 08:39
Cool, now it's working! Thanks a lot, Philip!
I was missing the second equal sign, just like you presumed...
Best regards
Florian
PS: You forgot the inletPatchIndex in the type-checking. It should be
if(U.boundaryField()[inletPatchIndex].type() != fixedValueFvPatchVectorField::typeName)
Just in case someone is copy-pasting it...
bigphil June 4, 2013 09:27
Best regards
Florian
Great.
Yep, thanks for the typo.
Philip
Carlen September 21, 2015 20:49
I am just wondering if this works in parallel
bigphil September 22, 2015 07:50
To get it to work in parallel, you must use globalFaceZones, and the patchToPatchInterpolation must be zoneToZoneInterpolation.
The latest FSI solvers and solidContact BCs do this.
Best,
Philip
Carlen September 22, 2015 21:24
Thank you philip,
can you kindly point me to where I can find the source code?
ali.m.1 January 28, 2016 12:48
updating BCs
1 Attachment(s)
Hi All
I've managed to follow this thread though, and get patchToPatchInterpolation working. I can see this by the info statements from the solver when running.
What I cannot do, is get the patch values to become the new BCs. Although the patch values are updating, they are not writing new boundary conditions. I think it's because I only have one loop in my solver, whereas I need 2 (at least). I'm trying to do the same as above, interpolate U1 from an outlet to an inlet.
Can anyone help? I've attached my .C file, sorry about the mess it's in.
Cheers
Ali
Edit: I have managed to get it to work now. I was solving both domains at the same time, instead of sequentially.
ali.m.1 February 4, 2016 09:11
Updating pressure gradient
Hi
Although I've managed to get velocity working fairly well, there is still a few issues:
I'm using reactingTwoPhaseEulerFoam. This first image shows on the water's velocity magnitude. The left pipe is using patchToPatchInterpolate for U, alpha, and p, whereas the right pipe is the 'standard', with no patches. You can see the patch on the left pipe, just before the bend. My aim is to get the left pipe looking like the right pipe, even although I have a baffle in there.
https://dl.dropbox.com/s/50kgso6rk9v...rison.png?dl=0
1) I cannot get the pressure fields to look correct. I've tried to do what Phil mentions in post #6, update the pressure gradient on the outlet, however I haven't managed this. I tried this by including another interpolator at the end of the while loop, but instead of going from outlet to inlet, it goes from inlet to outlet. See below image.
https://dl.dropbox.com/s/em75w9zqm21...rison.png?dl=0
Also, I haven't managed to include k or epsilon in the patchToPatch, but I don't think I need to. Correct me if I'm wrong!
Any help is appreciated.
Ali
Edit: I've managed to get the pressure distributions much more similar. The differences were due to the boundary conditions. The two cases are not identical yet though, but this could just be due to the interpolation carried out, giving averaging errors. I'm still unsure about my last question though, should I also be interpolating k, epsilon, and nut? If so, how is this possible?
ali.m.1 February 15, 2016 12:20
Hello
I have managed to interpolate U, p, and Alpha, however the results are different, as I'm not interpolating k + epsilon.
Does anyone know how to define these in the .C file? I can find where they are calculated, but can't seem to define them. I've been trying for 2 days now...
Ali
bigphil February 15, 2016 17:09
Originally Posted by ali.m.1 (Post 585277)
Hello
Ali
Hi Ali,
k + epsilon are defined in the turbulence model: see $FOAM_SRC/turbulenceModels/incompressible/RAS/kEpsilon.
So there are a few ways you could overwrite the k and epsilon boundary conditions; for example:
  • make a copy of the kEpsilon class and call it myKEpsilon and then you can add code to force the update of the boundary conditions;
  • lookup k and epsilon from the objectRegistry and use "const_cast" to overwrite the boundary conditions; but be careful as const_cast is typically not very elegant/safe.
Philip
ali.m.1 February 16, 2016 08:27
Originally Posted by bigphil (Post 585313)
Hi Ali,
Philip
Hi Philip
Thanks a lot for getting back. I found the kEpsilon.H file, but the trouble I'm having is defining the variables in my .C file, as it cannot find them. Or they 'were not declared in this scope'. Is it because they are 'private' as defined in the .H file?
I'm happy to update the values of k + epsilon by using patchToPatch (like I do with 'p' for example), however I cannot define them as variables. What would I need to add to 'myKEpsilon.H' to enable me to interpolate k + epsilon? I hope this is clearer...
Thanks again
Ali
EDIT: I managed to use them by using
volScalarField& k = const_cast<volScalarField&>(mesh.lookupObject<volScalarField>("k.water"));
Now that I am interpolating all variables, my solution is still more than 10% different to my standard case (where there is no baffle). Do you think this just due to the fact that both of adjacent cells to the baffle have the same values, and therefore causing the solution to be different? I currently have a coarse mesh, so I will try with a finer one, and see if this makes a difference.
