scalarSemiImplicitSource with time-varying values |
October 26, 2021, 08:44 |
Rep Power: 10 |
Dear all,
I'm trying to inject some tracer material into my simulation using the scalarSemiImplicitSource (in conjunction with a scalarTransport function object). All examples usually inject a fixed amount x for a fixed time t. I want to specify time-varying injection values now. So I am looking for a way to get my values into the scalarSemiImplicitSource (e.g. one value per second). Is there such a way? Or do I have to use the codedSource? (if I have to use the codedSource: How would I implement such a table there?) |
October 26, 2021, 10:17 |
Yann
Rep Power: 26 |
You should be able to define a table, the syntax might change depending of the OpenFOAM version you are using.
Yann |
October 26, 2021, 10:32 |
Rep Power: 10 |
Oh, that was easy. Should have read the header of the source completely! Thanks for pointing out the solution
November 9, 2021, 19:35 |
christopher
Rep Power: 8 |
Could you post your solution ? I am having a hard time with a similar problem.
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 02:05 |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 22:29 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
