-   OpenFOAM Running, Solving & CFD (https://www.cfd-online.com/Forums/openfoam-solving/)
-   -   Extremely slow simulation with interDyMFoam (https://www.cfd-online.com/Forums/openfoam-solving/116392-extremely-slow-simulation-interdymfoam.html)
jrrygg April 18, 2013 05:16
I am running a simulation with interDyMFoam (Air/Water, AMI with rotating and stationary mesh) which runs extremely slow, and I am looking for some ways to improve the performance. The main reason seems to be low time steps (e-8) to keep the Courant number < 1, but it should be possible to speed up the calculation of every time step I think.
I am looking for some comments on the residual targets/tolerances set in fvSolution, and maybe on my fvSchemes file also?
I recently increased the toleranse of the pressure terms to 1e-6 instead of 1e-8 too increase the speed of the simulations, could this be further increased?
I am running decomposed on 128 cores by the way.
Any tips on how to improve the performance will be greatly appreciated.
Regards,
Jone
Some output:
Interface Courant Number mean: 6.455324963e-06 max: 0.5005681575
Courant Number mean: 0.0002116964997 max: 0.5882487797
deltaT = 5.569042488e-08
Time = 0.006919137503
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.006919137503 transformation: ((0 0 0) (0.9738608726 (0 0.2271453297 0)))
AMI: Creating addressing and weights between 4453 source faces and 4453 target faces
AMI: Patch source weights min/max/average = 0.9985002144, 1.001921397, 1.000047858
AMI: Patch target weights min/max/average = 0.9990857617, 1.001532226, 1.000018088
Execution time for mesh.update() = 0.07 s
MULES: Solving for alpha1
Phase-1 volume fraction = 0.00295762538  Min(alpha1) = -1.735479458e-18  Max(alpha1) = 1
Phase-1 volume fraction = 0.002957636622  Min(alpha1) = -1.731270876e-18  Max(alpha1) = 1
Phase-1 volume fraction = 0.002957647861  Min(alpha1) = -1.732182027e-18  Max(alpha1) = 1
GAMG:  Solving for p_rgh, Initial residual = 0.02411778836, Final residual = 8.942364364e-07, No Iterations 40
time step continuity errors : sum local = 2.893569178e-13, global = 4.456094558e-14, cumulative = 9.7491866e-11
GAMG:  Solving for p_rgh, Initial residual = 0.01070900624, Final residual = 8.263136668e-07, No Iterations 17
time step continuity errors : sum local = 2.632099118e-13, global = -7.978696644e-15, cumulative = 9.74838873e-11
ExecutionTime = 61236.58 s  ClockTime = 61388 s
Interface Courant Number mean: 6.448986145e-06 max: 0.5055292675
Courant Number mean: 0.0002114044481 max: 0.5878898938
deltaT = 5.504594754e-08
Time = 0.006919192549
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.006919192549 transformation: ((0 0 0) (0.9738604585 (0 0.2271471051 0)))
AMI: Patch source weights min/max/average = 0.9985011005, 1.001921476, 1.00004786
AMI: Patch target weights min/max/average = 0.9990854226, 1.001532248, 1.000018089
Phase-1 volume fraction = 0.002957658974  Min(alpha1) = -1.733118704e-18  Max(alpha1) = 1
Phase-1 volume fraction = 0.002957670084  Min(alpha1) = -1.733538446e-18  Max(alpha1) = 1
Phase-1 volume fraction = 0.002957681198  Min(alpha1) = -1.734437289e-18  Max(alpha1) = 1
GAMG:  Solving for p_rgh, Initial residual = 0.02904518995, Final residual = 8.139273874e-07, No Iterations 38
time step continuity errors : sum local = 2.577957076e-13, global = -5.558341087e-14, cumulative = 9.742830389e-11
GAMG:  Solving for p_rgh, Initial residual = 0.01185015756, Final residual = 8.340824853e-07, No Iterations 24
time step continuity errors : sum local = 2.717511422e-13, global = 4.323848088e-14, cumulative = 9.747154237e-11
ExecutionTime = 61237.22 s  ClockTime = 61389 s
My fvSolution:
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    location    "system";
    object      fvSolution;
solvers
    pcorr
        solver          GAMG;
        tolerance      1e-06; //1e-08
        relTol          0;
        smoother        DIC;
        nPreSweeps      0;
        nPostSweeps    2;
        nFinestSweeps  2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels    1;
    p_rgh
        solver          GAMG;
        relTol          0;
        smoother        DIC;
        nPreSweeps      0;
        nPostSweeps    2;
        nFinestSweeps  2;
        mergeLevels    1;
    p_rghFinal
        solver          GAMG;
        relTol          0;
        smoother        DIC;
        nPreSweeps      0;
        nPostSweeps    2;
        nFinestSweeps  2;
        mergeLevels    1;
    U
        solver          smoothSolver;
        smoother        GaussSeidel;
        tolerance      1e-06;
        relTol          0;
        nSweeps        1;
    UFinal
        tolerance      1e-06;
        relTol          0;
        nSweeps        1;
PIMPLE
    momentumPredictor no; //yes
    nCorrectors    2;
    nNonOrthogonalCorrectors 0;
    nAlphaCorr      1;
    nAlphaSubCycles 3;
    cAlpha          1.5;
    correctPhi      no;
  /* pRefPoint      (0.0013 0.0017 0.0017);
    pRefValue      1e5; */
relaxationFactors
    fields
    equations
        "U.*"          1;
fvSchemes:
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default        Euler;
gradSchemes
    default        Gauss linear;
divSchemes
    div(rho*phi,U)  Gauss limitedLinearV 1;
    div(phi,alpha)  Gauss vanLeer01;
    div(phirb,alpha) Gauss interfaceCompression;
    //Following added because of crash on Vilje
    div((muEff*dev(T(grad(U))))) Gauss linear;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default        Gauss linear limited 1.0;
interpolationSchemes
    default        linear;
snGradSchemes
    default        limited 1.0;
fluxRequired
    default        no;
    p_rgh;
    pcorr;
    alpha;
sail April 22, 2013 11:56
increasing the tolerance is definitely not what i would raccomand. you are trading a small speedup for accuracy. definitely a no-no.
any chanches you can use a coarser mesh? the courant number is set by the cell size and the flow velocity so increasing the cell size lowers the Courant number, thus allowing a higher timestep. also, check your maeh, maybe it is just a cell or two that are small and are slowing down all the simulation.
I don't know if this strategy is doable for your case though.
another thing you might want to try is to initialize the case with the mesh steady, maybe even using LTSInterFoam, even without turbulent quantities, just to do not start you simulation with big local velocities given by the mesh movement (I'm just guessing, something like a propeller rotating at 300 rpm, inflow velocity 10 ms, and there you go, big relative speed between flow and mesh motion, because the flow haven't picked it up yet...)
ngj April 22, 2013 12:45
Hi Jone,
From my experience with moving meshes and VOF methods, then you really have to consider the following:
momentumPrediction on;
nCorrectors 3; // At least. I sometimes use as many as 5
nNonOrthogonalCorrectors <larger>?;
With respect to the non-orthogonal correctors, then you are using a method with rotating meshes, which must give rise to at least occasional high non-orthogonalities.
In addition, I have read some threads about poor performance of the AMI on a large number of processors. You might consider the need of 128 processors, now that one iteration only takes 0.64 s.
Kind regards
Niels
sail April 22, 2013 14:21
Originally Posted by ngj (Post 422360)
Hi Jone,
Kind regards
Niels
silly me, I haven't noticed that. how big is your mesh?
jrrygg April 22, 2013 16:55
Vieri and Nils, thank you very much for your answers! I will look into them tomorrow morning.
My mesh is around 1 million cells, so not that big. In CFX it takes less than 1/10 of the time with 4 millions, so I really donīt get it.
I agree that the mesh might be the reason, I actually think that there are a couple of very small cells limiting the simulation time. Maybe I can find a way to limit the min cell size in Ansys Meshing to compare the speed.
Initialization is a very good idea that I will look into.
Have a good evening!
Regards,
Jone
sail April 22, 2013 17:02
128 cores for a 1 million mesh it is really too much. I do think that you are getting too much mpi communication overhead.
try with a more reasonable number, like 20-40 cores top.
jrrygg April 23, 2013 04:50
First of all, I also tried with a coarser mesh. It was ok in checkMesh, but it stilled crashed with the following error:
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  in "/lib/x86_64-linux-gnu/libc.so.6"
#3  void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#4  void Foam::MULES::limit<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::zeroField const&, Foam::zeroField const&, double, double, int, bool) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5  Foam::MULES::explicitSolve(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, double, double) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
 in "/opt/openfoam211/platforms/linux64GccDPOpt/bin/interDyMFoam"
#7  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Last timesteps:
Interface Courant Number mean: 1.597370001e-13 max: 3.367889415e-08
Courant Number mean: 8.492343262e-05 max: 47.93150517
deltaT = 1.542054914e-14
Time = 5.124667456e-05
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 5.124667456e-05 transformation: ((0 0 0) (0.9999985598 (0 0.001697167211 0)))
AMI: Creating addressing and weights between 1860 source faces and 1860 target faces
AMI: Patch source weights min/max/average = 0.9999999855, 1.000273407, 1.00002072
AMI: Patch target weights min/max/average = 0.9999986967, 1.000284245, 1.000020412
Execution time for mesh.update() = 0.25 s
--> FOAM Warning :
    From function Time::operator++()
    in file db/Time/Time.C at line 1010
    Increased the timePrecision from 10 to 11 to distinguish between timeNames at time 5.124667455e-05
Phase-1 volume fraction = 2.340101492e-05  Min(alpha1) = -2.94026316e-21  Max(alpha1) = 1
Phase-1 volume fraction = 2.340101492e-05  Min(alpha1) = -2.940263151e-21  Max(alpha1) = 1
Phase-1 volume fraction = 2.340101493e-05  Min(alpha1) = -2.940263144e-21  Max(alpha1) = 1
smoothSolver:  Solving for Ux, Initial residual = 0.03289536739, Final residual = 5.931840904e-09, No Iterations 22
smoothSolver:  Solving for Uy, Initial residual = 0.02652586093, Final residual = 6.490399401e-09, No Iterations 21
smoothSolver:  Solving for Uz, Initial residual = 0.06385161287, Final residual = 9.329710362e-09, No Iterations 22
GAMG:  Solving for p_rgh, Initial residual = 0.8168173646, Final residual = 5.329552555e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.5691559964, Final residual = 4.333370438e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.6077577617, Final residual = 5.096296929e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.5588035124, Final residual = 4.970930311e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.6553288826, Final residual = 6.082410996e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.6012161847, Final residual = 5.743818456e-09, No Iterations 20
time step continuity errors : sum local = 2.767907786e-13, global = 6.720125451e-14, cumulative = -4.563931424e-06
GAMG:  Solving for p_rgh, Initial residual = 0.7547558975, Final residual = 8.26595506e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.4767521403, Final residual = 4.33189641e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.500681991, Final residual = 5.307664532e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.4631253002, Final residual = 4.796368045e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.5959068421, Final residual = 6.221265876e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.5300655458, Final residual = 5.512629022e-09, No Iterations 20
time step continuity errors : sum local = 6.317765168e-13, global = 1.567796998e-13, cumulative = -4.563931267e-06
GAMG:  Solving for p_rgh, Initial residual = 0.6942039022, Final residual = 7.554443004e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.5165126574, Final residual = 5.254193207e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.6475607497, Final residual = 6.787541225e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.5574720976, Final residual = 5.810655172e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.7423454876, Final residual = 7.734423209e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.6165483516, Final residual = 6.41331222e-09, No Iterations 20
time step continuity errors : sum local = 1.508767972e-12, global = 3.749318923e-13, cumulative = -4.563930892e-06
GAMG:  Solving for p_rgh, Initial residual = 0.8276795512, Final residual = 8.954560476e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.558609031, Final residual = 5.530478839e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.6826850609, Final residual = 7.158367366e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.5769959496, Final residual = 5.989697425e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.7749635251, Final residual = 8.06470252e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.6336308451, Final residual = 6.581617802e-09, No Iterations 20
time step continuity errors : sum local = 3.559817726e-12, global = 8.850757951e-13, cumulative = -4.563930007e-06
GAMG:  Solving for p_rgh, Initial residual = 0.8547424795, Final residual = 9.199343842e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.5841017513, Final residual = 5.844350229e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.7306124828, Final residual = 7.63158262e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.6069032171, Final residual = 6.294821239e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.8194731067, Final residual = 8.514487236e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.6594746017, Final residual = 6.843822577e-09, No Iterations 20
time step continuity errors : sum local = 8.411599725e-12, global = 2.092559032e-12, cumulative = -4.563927914e-06
ExecutionTime = 501.96 s  ClockTime = 502 s
Interface Courant Number mean: 1.770494893e-13 max: 4.980492024e-08
Courant Number mean: 0.0002330663221 max: 139.7058538
deltaT = 1.103786901e-15
Time = 5.1246674565e-05
Execution time for mesh.update() = 0.23 s
--> FOAM Warning :
    Increased the timePrecision from 11 to 12 to distinguish between timeNames at time 5.124667456e-05
Phase-1 volume fraction = 2.340101493e-05  Min(alpha1) = -2.940263142e-21  Max(alpha1) = 1
Phase-1 volume fraction = 2.340101493e-05  Min(alpha1) = -2.94026314e-21  Max(alpha1) = 1
Phase-1 volume fraction = 2.340101493e-05  Min(alpha1) = -2.940263136e-21  Max(alpha1) = 1
smoothSolver:  Solving for Ux, Initial residual = 0.06477118372, Final residual = 8.642332518e-09, No Iterations 26
smoothSolver:  Solving for Uy, Initial residual = 0.02933841898, Final residual = 6.713449257e-09, No Iterations 25
smoothSolver:  Solving for Uz, Initial residual = 0.1070822693, Final residual = 8.780816192e-09, No Iterations 27
GAMG:  Solving for p_rgh, Initial residual = 0.8893907442, Final residual = 6.03093516e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.2999964081, Final residual = 4.400563944e-09, No Iterations 19
GAMG:  Solving for p_rgh, Initial residual = 0.2001912473, Final residual = 4.323988997e-09, No Iterations 19
GAMG:  Solving for p_rgh, Initial residual = 0.1991798232, Final residual = 4.856585103e-09, No Iterations 19
GAMG:  Solving for p_rgh, Initial residual = 0.2166203943, Final residual = 5.449721145e-09, No Iterations 19
GAMG:  Solving for p_rgh, Initial residual = 0.2325097647, Final residual = 5.987364552e-09, No Iterations 19
time step continuity errors : sum local = 2.31991253e-13, global = 4.653817902e-14, cumulative = -4.563927868e-06
GAMG:  Solving for p_rgh, Initial residual = 0.2530189377, Final residual = 6.73790163e-09, No Iterations 19
GAMG:  Solving for p_rgh, Initial residual = 0.2376544809, Final residual = 6.337231792e-09, No Iterations 19
GAMG:  Solving for p_rgh, Initial residual = 0.2508918284, Final residual = 7.096666627e-09, No Iterations 19
GAMG:  Solving for p_rgh, Initial residual = 0.2671706917, Final residual = 7.384764598e-09, No Iterations 19
GAMG:  Solving for p_rgh, Initial residual = 0.3142132031, Final residual = 8.694850032e-09, No Iterations 19
GAMG:  Solving for p_rgh, Initial residual = 0.3269917566, Final residual = 8.999909757e-09, No Iterations 19
time step continuity errors : sum local = 4.947432806e-13, global = 1.061610488e-13, cumulative = -4.563927762e-06
GAMG:  Solving for p_rgh, Initial residual = 0.3896779346, Final residual = 4.01177967e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.3602979394, Final residual = 9.679480202e-09, No Iterations 19
GAMG:  Solving for p_rgh, Initial residual = 0.4086001377, Final residual = 4.23695469e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.4096242098, Final residual = 4.220163954e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.4891555194, Final residual = 5.018675493e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.4798885981, Final residual = 4.903916905e-09, No Iterations 20
time step continuity errors : sum local = 4.304573434e-13, global = 9.361216275e-14, cumulative = -4.563927668e-06
GAMG:  Solving for p_rgh, Initial residual = 0.5731626992, Final residual = 5.785088066e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.4692696901, Final residual = 4.65822784e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.5222446816, Final residual = 5.323751511e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.5051875075, Final residual = 5.107623445e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.6048712058, Final residual = 6.10837163e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.5734690483, Final residual = 5.770318327e-09, No Iterations 20
time step continuity errors : sum local = 9.866099684e-13, global = 2.125564627e-13, cumulative = -4.563927455e-06
GAMG:  Solving for p_rgh, Initial residual = 0.6854054465, Final residual = 6.829505031e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.537832268, Final residual = 5.286631514e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.5994082542, Final residual = 6.028535219e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.5680692402, Final residual = 5.673560985e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.6801833379, Final residual = 6.789791194e-09, No Iterations 20
GAMG:  Solving for p_rgh, Initial residual = 0.6322346784, Final residual = 6.292624607e-09, No Iterations 20
time step continuity errors : sum local = 2.267217457e-12, global = 4.844195478e-13, cumulative = -4.563926971e-06
ExecutionTime = 540.1 s  ClockTime = 540 s
Interface Courant Number mean: 1.178773889e-13 max: 3.493308291e-08
Courant Number mean: 8.800536524e-05 max: 51.12002034
deltaT = 2.159206695e-16
Time = 5.12466745648e-05
I played around with the parameters in fvSolution for this one with no success.
About the number of cores you are right, it is too many. But anyway it has been running way faster with 128 than with 8 cores. I heard before that there should be around 50k cells for each core, so 20 could be a good number of cores.
I am trying to initialize with potentialFoam by adding these lines to fvSolutions:
potentialFlow
    nNonOrthogonalCorrectors 10;
How can I use LTSInterFoam to initialize? The quantities are quite large as you say, inlet speed of almost 40 ms-1 and quick rotation.
sail April 23, 2013 07:55
your simulation is beyond recovery earlier than that. with the auto time stepping you are already at a DeltaT =1e-14 s, average courant number of 8 and max Co 45.
i dont' know what you changed or if it is the mesh but something went horribly wrong earlier.
I'd suggest to disable the autotimestep, at least for the tests. in this way if there is an issue the sim crashes instantly instead of dragging up wasting time. consider it as euthanasia.
to initialize the solution, change the time scheme in your control dict and just run LTSInterFoam instead of interDyMFoam. it will tell you if something is amiss. if you want to be really cool, add a MRF zone at your rotating region.
than you can bring the developed field into your simulation.
jrrygg April 23, 2013 08:01
Thank you Vieri!
So should I run the full simulation with LTSInterFoam, or just the first timestep(s)? How do I apply the result so that it initializes interDyMFoam?
About this particular simulation that crashed it must be something wrong with the mesh. I tried to make a coarser mesh just for testing, but I guess it resolves the flow very poorly.
sail April 23, 2013 10:14
it is very problem dependent, but i'd say run not necessarly until convergence, but not far from it either. 1000-3000 iterations, maybe?
use mapFields to move the data or just edit manually the BCs if needed.
