When i run my case...crashhh
5 Attachment(s)
Dear Foamers,
I am doing an air jet simulation , my geometry is OK according to checkMesh. I ran my case and after moving about the start way of my simulation, the running had some high and crazy results, I do not why? .. can any body helps me please because I tried with differents fvSolutions and fvSchemes files but not got good results . I tried differents ways, first only without rig, then without stayl and asimsails but crash too If somebody can i help me... Thanks in advanced Simón /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : checkMesh Date : Apr 25 2013 Time : 10:05:46 Host : "simon-simon" PID : 3591 Case : /home/simon/Escritorio/POINTWISEmallas/ejemplovelaspointwise nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 313652 faces: 3374127 internal faces: 3239593 cells: 1649842 boundary patches: 12 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 14352 tet wedges: 0 tetrahedra: 1635490 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology asim 44386 22195 ok (closed singly connected) deck 3441 1832 ok (non-closed singly connected) hull 4934 2680 ok (non-closed singly connected) main 6970 3487 ok (closed singly connected) rig 14956 14656 ok (closed singly connected) stayl 6954 3479 ok (closed singly connected) xmax 9948 5148 ok (non-closed singly connected) xmin 9906 5127 ok (non-closed singly connected) ymax 7222 3761 ok (non-closed singly connected) ymin 17795 9149 ok (non-closed singly connected) zmax 4030 2140 ok (non-closed singly connected) zmin 3992 2121 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-64.5 -0.000207407 -75) (85.5 60 75) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (4.36547e-16 2.02156e-15 -1.58891e-16) OK. Max cell openness = 4.21878e-16 OK. Max aspect ratio = 44.4492 OK. Minumum face area = 1.73905e-05. Maximum face area = 13.2876. Face area magnitudes OK. Min volume = 4.89894e-08. Max volume = 15.3649. Total volume = 1.34994e+06. Cell volumes OK. Mesh non-orthogonality Max: 84.6841 average: 22.4909 *Number of severely non-orthogonal faces: 1495. Non-orthogonality check OK. <<Writing 1495 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 2.81383 OK. Coupled point location match (average 0) OK. Mesh OK. End Attachment 21112 Attachment 21113 Attachment 21114 Attachment 21115 Attachment 21116 |
CheckMesh seems to be fine, but look at this Mesh non-orthogonality Max: 84.6841 average: 22.4909 *Number of severely non-orthogonal faces: 1495. Non-orthogonality check OK. <<Writing 1495 non-orthogonal faces to set nonOrthoFaces You should check the location of these cells in paraFoam (select include sets), if they are in a boundary layer 84 degress can cause some problems. Can you also put the log file from the solver to see how it crashes? |
Thanks Ignacio
Attached the file forces.dat ,you will look that the pressure results growing very fast around Time 100, really dont crash the case but the results are not good. Attached non-orthogonal file...about that how is possible get better this??? maybe in fvSolution: SIMPLE { nNonOrthogonalCorrectors 4????????????????????????????????????????????????; pRefCell 0; pRefValue 0; } Thanks a lot. Simón |
Hola Simon,
Hablo Espanol, pero te respondo en ingles para que sea mas facil para los demas ayudarte. In paraFoam do: Properties tree > Select Include Sets > A new icon will appear in Mesh Parts box, select it > Apply. I guess 4 non-orthogonal correctors is fine. But you can always increase it till.. lets say 15. The simulation will stop when the variable reaches the tolerance that you define, so it wont increase a lot the computational time. What did you use to create the mesh? ICEM? snappyHexMesh? if you used ICEM you can use the option of improving orthogonality automatically. |
Thanks Ignacio
Now i can check nonortogonal faces I try run the case with nNonOrthogonalCorrectors 4 or more and then I will tell you the results I did the mesh with Pointwise, I will try getting better the mesh in Pointwise and I will run the case with nNonOrthogonalCorrectors 4 or more and then I will tell you the results. Tnaks for everything Simón |
running potentialfoam
Hello everybody, it's my first time and i really need help to run potentialfoam with cylinder i've always got this following error:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword 'const' on line 52 and ending at line 137" file: /home/sid-major/OpenFOAM/root-2.2.0/run/tutorials/basic/potentialFoam/cylinder/system/controlDict at line 137. From function primitiveEntry::readEntry(const dictionary&, Istream&) in file lnInclude/IOerror.C at line 132. FOAM exiting can someone help me please? |
