April 26, 2013, 08:04 |
engineFoam - kiva tutorial
klemen
Rep Power: 13 |
I am studying the kiva tutorial. I changed the kiva mesh to OpenFoam mesh as described in Allrun script (kivaToFoam -file otape17). Then i checked the generated documents.
I duplicated the setup with different piston space geometry and run the engineFoam solver. After that i checked the solution with paraFoam, but i could not see the piston wall movement and mesh changes as seen with original kiva tutorial. I could not find any instructions about the dynamic mesh. There are some info in engineGeometry file, but i could not find any info about "cylinder wall" moving toward the "pistonHead wall". Which file contains these information? Regards Klemen |
May 3, 2013, 12:56 |
klemen
Rep Power: 13 |
Anybody ever tried this. Any idea where can i find the documentation about the engineFoam solver...
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 08:45 |
Weird problem with engineFoam tutorial | chris1980 | OpenFOAM Running, Solving & CFD | 29 | August 28, 2013 06:53 |
Problem on Fluent Tutorial: Horizontal Film Boilig | Feng | FLUENT | 2 | April 13, 2013 05:34 |
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread | wyldckat | OpenFOAM Installation | 2 | July 11, 2012 16:01 |
PDF - conserved scalar approach in KIVA | vega | Main CFD Forum | 0 | July 5, 2005 02:49 |
