interDyMFoam "keyword displacementLaplacianCoeffs is undefined"
Old   April 30, 2013, 17:29
Default interDyMFoam "keyword displacementLaplacianCoeffs is undefined"
kilroy's Avatar
kilroy is on a distinguished road
I am using "waveDyMFoam" for my research and I basically modified it from "interDyMFoam" solver. I followed the steps described in the wiki below:
https://sites.google.com/site/jordim...ic-mesh-motion
The solver has been compiled pretty fine and it is working right now. After that I tried to run the "waveFlumeDyM" tutorial that can be downloaded at the bottom of the link that I have provided above.
But after I run the "waveDyMFoam" solver, I get the error below:
Selecting motion solver: displacementLaplacian
--> FOAM FATAL IO ERROR:
keyword displacementLaplacianCoeffs is undefined in dictionary "/home/meta/OpenFOAM/kilroy-2.2.0/Documents/examples/7th/tutorials/waveFlumeDyM/constant/dynamicMeshDict"
file: /home/meta/OpenFOAM/kilroy-2.2.0/Documents/examples/7th/tutorials/waveFlumeDyM/constant/dynamicMeshDict from line 17 to line 23.
From function dictionary::subDict(const word& keyword) const
in file db/dictionary/dictionary.C at line 608.
FOAM exiting
I am not sure if this error is because I did something wrong during the modification process from interDyMFoam to waveDyMFoam or because version incompatibility.
Have anybody encountered the same problem before and know how to solve it?
Thank you very much for your time.
Kilroy
kilroy is offline   Reply With Quote
Old   April 30, 2013, 20:35
Emanuele Leggio
nanes is on a distinguished road
The solver must find inside dynamicMeshDict the keyword displacementLaplacianCoeffs, than you must put into dynamicMeshDict this keyword and subsequent braces.
Try to read this file from one tutorial:
https://github.com/OpenFOAM/OpenFOAM...ynamicMeshDict
nanes is offline   Reply With Quote
Old   April 30, 2013, 21:27
kilroy's Avatar
Emanuele
Thank you so much. I forgot the braces, that was the problem. Now my case works pretty fine
Kilroy
Old   May 1, 2013, 10:57
kilroy's Avatar
I was also wondering, is it possible to restrain some degrees of freedom in "interDyMFoam"?
For example, can I make my object free to translate in y and z directions and free to rotate in x, y and z but restrained to move in the x direction?
Kilroy
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 15 October 15, 2021 06:35
GAMG problem in interDyMFoam? ribe OpenFOAM 4 July 17, 2013 22:23
interDyMFoam with GGI in 3d stawrogin OpenFOAM Running, Solving & CFD 2 January 5, 2011 02:17
error using interDyMFoam with kOmegaSST to simulate sloshing anmartin OpenFOAM Running, Solving & CFD 0 July 20, 2010 13:21
Turning interDymFoam into a turbulence solver Saúl Balsa OpenFOAM Running, Solving & CFD 3 June 30, 2010 16:09
