pimpleDyMFoam failed in tutorial cases (2.2.x)
Old   May 6, 2013, 22:05
Default pimpleDyMFoam failed in tutorial cases (2.2.x)
waku2005 is on a distinguished road
Dear All,
I'm using 2.2.x and recently experienced strange failures in using pimpleDyMFoam after "git pull".
In the four pimpleDyMFoam tutorials, here are my results.
1) propeller ... failed after 1 time step
2) mixerVesselAMI2D ... failed after 1 time step
3) movingCone ... success and results are OK
4) wingMotion .... success and results are OK
The 2 failed cases are both finished with Floating point exception after only 1 time step.
I think something is wrong in dynamic mesh process in particularly rotation of meshes.
Any information will be appreciated and thanks in advance !
waku2005
[waku@ensis10 mixerVesselAMI2D]$ pimpleDyMFoam
|  \\    /   O peration     | Version:  2.2.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.x-d2301c6b77ea
Exec   : pimpleDyMFoam
Date   : May 07 2013
Time   : 11:01:03
Host   : "ensis10"
PID    : 7243
Case   : /home/waku/OpenFOAM/waku-2.2.x/tutorials/incompressible/pimpleDyMFoam/mixerVesselAMI2D
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid-body motion function rotatingMotion
Applying solid body motion to cellZone rotor
Reading field p
Reading field U
AMI: Creating addressing and weights between 96 source faces and 96 target faces
AMI: Patch source weights min/max/average = 1, 1, 1
AMI: Patch target weights min/max/average = 1, 1, 1
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading field rAU if present
Creating fintite volume options from fvOptions
Selecting finite volume options model type MRFSource
    Source: MRF1
    - applying source for all time
    - selecting cells using cellZone rotor
    - selected 1536 cell(s) with volume 0.000100459
PIMPLE: Operating solver in PISO mode
Starting time loop
Courant Number mean: 0 max: 0
deltaT = 0.00119048
Time = 0.00119048
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 0.00119048 transformation: ((0 0 0) (0.999999 (0 0 0.00124666)))
AMI: Patch source weights min/max/average = 0.0381209, 0.961918, 0.50002
AMI: Patch target weights min/max/average = 0, 1.00004, 0.50002
#0  Foam::error::printStack(Foam::Ostream&) in "/home/waku/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/home/waku/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
 at sigaction.c:0
#3  Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) in "/home/waku/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/waku/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/bin/pimpleDyMFoam"
#6  __libc_start_main in "/lib64/libc.so.6"
[waku@ensis10 OpenFOAM-2.2.x]$ git log
commit d2301c6b77ea0962b708dfd87628ec4818688f4d
Merge: 85a2812 39d7777
Author: Henry <Henry>
Date:   Mon May 6 21:36:45 2013 +0100
    Merge branch 'master' of github.com:OpenFOAM/OpenFOAM-2.2.x
waku2005 is offline   Reply With Quote
Old   May 7, 2013, 00:02
Dongyue Li
sharonyue is on a distinguished road
Source: MRF1
Are you using pimpleDyMFoam?So in this two rotating case.and in dynamic mesh solver , it should not have MRF,rite? try to delete it.
sharonyue is offline   Reply With Quote
Old   May 7, 2013, 02:08
Hi
In the fvOptions, MRF zone is inactive and has no effects to AMI.
This fvOptions file is as provided by OF 2.2.x initial branch and never changed.
waku2005
// MRF source to enable comparison between AMI and MRF case
// Note: inactive by default
MRF1
type MRFSource;
active no; <<<<<<<<<<<<<<<
selectionMode cellZone;
cellZone rotor;
MRFSourceCoeffs
// Fixed patches (by default they 'move' with the MRF zone)
nonRotatingPatches ();
origin (0 0 0);
axis (0 0 1);
omega constant 104.72;
Old   May 13, 2013, 04:28
Hi All
Recent update solved the problem and now get working fine in all tutorials.
Regards
waku2005
Tutorial Cases (Help) Rophys OpenFOAM Running, Solving & CFD 7 April 21, 2022 00:54
Vessel tutorial problem hosseinhgf CFX 1 March 17, 2013 11:39
Exchanging the geomtry in the LES motorBike tutorial simpomann OpenFOAM 1 May 26, 2012 08:26
STAR-CD Tutorial shekhar aryal STAR-CD 4 March 22, 2010 03:25
Problem in running tutorial cases preetham OpenFOAM Installation 2 June 13, 2009 16:36
