OpenFoam 2.2 fvOptions temperature limits
Like Tree5Likes
  • 5 Post By fredo490
Old   May 7, 2013, 02:28
Default OpenFoam 2.2 fvOptions temperature limits
HECKMANN Frédéric
fredo490 is on a distinguished road
Dear all,
As some of you know, OF 2.2 introduce a new system of "fvOptions" files where we can set the porosity and so on...
There is another interesting command that is "temperatureLimitsConstraint". As its name says, it is used to constraint the temperature to a minimum and maximum value.
Because I didn't find any example online, here is my file:
You have to put it into the "fvOptions" file located in system
source1
    type            temperatureLimitsConstraint;
    selectionMode   all;
    active          true;
        temperatureLimitsConstraintCoeffs
            Tmin     220;
            Tmax     270;
This command will bound the temperature between 220K and 270K in all the domain. It is useful in some cases if your compressible solver can't catch the value temperature value during the first iterations.
Edit: the page description come from here: http://www.openfoam.org/version2.2.0/fvOptions.php
nsf, andrejssab, DanielFB and 2 others like this.
fredo490 is offline   Reply With Quote
Old   July 11, 2013, 15:39
Hann Mao
hsmao is on a distinguished road
Thanks for the tip!
Does this work for all compressible solvers? I tried adding this to sonicFoam and it seems to get ignored.
hsmao is offline   Reply With Quote
Old   July 11, 2013, 18:49
HECKMANN Frédéric
As I remember, sonic foam is mostly hard coded so it might not work.
To check, find the thermo equation in the source code and check if you can find a line with "+ fvoptions" or something similar.
Old   July 11, 2013, 22:10
ksv
ksv
ksv is on a distinguished road
Hi Fredo,
Thanks for your tip. May i know whether there exists similar options to control turbulent kinetic energy k and epsilon?
ksv
ksv is offline   Reply With Quote
Old   July 12, 2013, 05:11
HECKMANN Frédéric
For k, omega et epsilon, you can add a simple code such as:
	k= max(k, kMin);
	k= min(k, kMax);
where kMin and kMax can be defined in the code or by a dimensionedScalar and a IOdictionary.
We must use fOption for T because T is not a variable used by OpenFoam. The function "fOption" actually modify the thermo equation (enthalpy) to correct the temperature.
Old   April 30, 2014, 07:19
Vesselin Krastev
vkrastev is on a distinguished road
sorry for re-opening this thread but I'm using the temperatureLimitsConstraint in conjunction with chtMultiRegionFoam (OF-2.2.x, latest available update) and it actually doesn't seem to me it's working as it is supposed to. The fvOptions dict appears to be read properly, but when the enthalpy equation is solved the temperature violates the imposed bounds, even if all the discretization schemes should be bounded/limited. Here there are my fvSchemes and fvOptions dictionaries (there is only one fluid region at this stage), together with an extract of runtime output log.
fvSchemes:
ddtSchemes
    default         Euler;
gradSchemes
    default         cellMDLimited Gauss linear 1;
    grad(U)         cellMDLimited Gauss linear 0.5;
    //grad(h)         faceLimited Gauss linear 1;
divSchemes
    default        none;
    div(phi,U)      bounded Gauss linearUpwindV grad(U);
    div(phi,K)      bounded Gauss linear;
    div(phi,h)      bounded Gauss limitedGamma 1 264157 294289;
    div(phi,k)      bounded Gauss upwind;
    div(phi,epsilon) bounded Gauss upwind;
    div(R)          Gauss linear;
    div((muEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(muEff,U) Gauss linear limited 0.333;
    laplacian(Dp,p_rgh) Gauss linear limited 0.333;
    laplacian(alphaEff,h) Gauss linear limited 0.333;
    laplacian(DkEff,k) Gauss linear limited 0.333;
    laplacian(DepsilonEff,epsilon) Gauss linear limited 0.333;
interpolationSchemes
    default         linear;
snGradSchemes
    default         limited 0.333;
fluxRequired
    default         no;
    p_rgh;
fvOptions:
temperature_constraints
    active        yes;
    selectionMode cellZone;
    cellZone      fluid;
            Tmin     263;
            Tmax     293;
log:
Region: fluid Courant Number mean: 1.4132369e-05 max: 0.98128545
deltaT = 2.381967e-05
Time = 0.000100306
Solving for fluid region fluid
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG:  Solving for Ux, Initial residual = 0.00081227894, Final residual = 1.6049071e-07, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.07792845, Final residual = 1.8250737e-05, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.0014009406, Final residual = 3.9984243e-07, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.000399081, Final residual = 8.990734e-08, No Iterations 1
Min/max T:262.29196 299.81974
Min/max rho:1.1716795 1.347332
GAMG:  Solving for p_rgh, Initial residual = 0.0007644805, Final residual = 1.345729e-05, No Iterations 3
GAMG:  Solving for p_rgh, Initial residual = 6.2938682e-05, Final residual = 1.757067e-06, No Iterations 2
time step continuity errors (fluid): sum local = 3.6194871e-09, global = -1.1723455e-09, cumulative = 9.1079573e-09
Min/max rho:1.1709893 1.3499513
GAMG:  Solving for p_rgh, Initial residual = 1.1436979e-05, Final residual = 3.3044886e-07, No Iterations 2
GAMG:  Solving for p_rgh, Initial residual = 2.5426255e-06, Final residual = 4.4810886e-08, No Iterations 2
time step continuity errors (fluid): sum local = 9.2017652e-11, global = -1.1644798e-11, cumulative = 9.0963125e-09
DILUPBiCG:  Solving for epsilon, Initial residual = 4.9736441e-05, Final residual = 2.2259148e-08, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 8.5244714e-13, Final residual = 1.2977543e-16, No Iterations 1
bounding k, min: 4.9998752e-16 max: 1.15 average: 0.0022126182
Any comments about this?
V.
vkrastev is offline   Reply With Quote
Old   July 15, 2014, 16:08
Charles McCreary
crmccreary is on a distinguished road
Typically in a CHT analysis, the system directory will have subdirectories for each region. Did you put the fvOptions file in the relevant subdirectory? Also, at the top of the log file, OpenFOAM will tell you what it has read from the fvOptions file.
*UPDATE*
Same behavior here. Doesn't seem to limit the temperature at all.
crmccreary is offline   Reply With Quote
Old   July 15, 2014, 16:57
Vesselin Krastev
Yes.
*UPDATE*
Well, in my case the wrong max/min temperatures in the domain appeared to be related to the externalWallHeatFluxTemperature boundary condition, which is evidently affected by some bad implementation issue in the OF-2.2.x branch and goes always unstable unless an EXTREMELY fine near wall grid is arranged (I've checked this behavior for a simple 2D buoyancy driven cavity flow, see this tread for further details: http://www.cfd-online.com/Forums/ope...tml#post496092 ). Regarding the fvOptions temperature constraint, I haven't investigated it any further so I cannot add more useful information about it.
Best
V.
Old   July 15, 2014, 17:33
Charles McCreary
I was using the 2.3.x branch. Temperature in the solid blows up, not obeying the fvOptions limit. I suspect that, for some reason, diffusion at the boundary becomes zero thus zero heat flux at the boundary and the applied heat flux (fixed gradient on the solid) yields a near infinite temperature on the solid. Just a guess.
Old   December 30, 2014, 09:27
Derek Mitchell
derekm is on a distinguished road
THis does work in chtMultiRegionSimpleFoam in V2.3.1
in conjunction with scalarSemiImplicitSource
to construct a heat source limited by temperature
the comment in header file gives the wrong names for the coeffs it is Tmin and Tmax
not maximum and minimum.
   Temperaturelimit1
        active          true;
        selectionMode   all;
            Tmin     200;
            Tmax     340;
    energySource1
        type            scalarSemiImplicitSource;
        active          true;
        selectionMode   all;
        scalarSemiImplicitSourceCoeffs
            volumeMode      specific;
            injectionRateSuSp
                h           (  20000 0 ); // 2e4 = 20w/litre
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET
derekm is offline   Reply With Quote
Old   August 27, 2018, 05:56
Foad
foadsf is on a distinguished road
Adding a fvOptions file in system folder with :
temperatureLimit
    type limitTemperature;
    active true;
    limitTemperatureCoeffs
        selectionMode all;
        min <Tmin>;
        max <Tmax>;
seems to resolve the issue.
foadsf is offline   Reply With Quote
Old   December 16, 2019, 16:07
Thomas
hand90 is on a distinguished road
Hi everyone
My simulation in OF v1806 using rhoSimpleFoam crashed after very few iterations due to divergence in temperature. After limiting the temperature the solver runs very well.
Now the same simulation has a very similar behaviour in foam-extend 4.0 when using dbnsTurbFoam. When I tried to apply limits I realised that fvOptions is not available in the foam-extend version. Does anyone know a work around or how I can apply limits?
Many thanks.
hand90 is offline   Reply With Quote
Old   January 17, 2020, 00:59
Default Limit temperature within the inner loop?
  #13
Stanley John
sjohn2 is on a distinguished road
Is there a way to limit temperature within the inner loop?
My temparature blows up within a loop?
I am also interested in limiting the temperature for another variable interface temperature Tf? Anybody having any ideas?
I am using interfacecomposition model in reactingTwoPhaseEulerFoam?
Thanks
Stanley
sjohn2 is offline   Reply With Quote
Is wall ajacent temperature equal to conservative temperature of the wall? shenying0710 CFX 8 January 4, 2013 05:03
Free stream temperature in tube wall saharesobh FLUENT 2 November 19, 2012 08:32
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
The OpenFOAM extensions project mbeaudoin OpenFOAM 16 October 9, 2007 10:33
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
