-   -   wall tangential temperature gradient (http://www.cfd-online.com/Forums/openfoam-solving/117394-wall-tangential-temperature-gradient.html)
apatronis May 7, 2013 17:33
Hi all,
Does anyone know how to apply a temperature gradient along the walls of a simple channel (so wall temperature varies in the streamwise direction). I'm looking at using rhoCentralFoam to simulate a surface temperature gradient driven gas flow. Can I manage this with groovyBC?
Thanks
fredo490 May 8, 2013 02:53
What you want is a boundary condition with a variable value depending of the position ?
I don't know if OF has a derived boundary able to do this. Usually people use the "swak4foam" library to perform this kind of special boundary. You can use the groovyBC, google will help you.
The official website is here : http://openfoamwiki.net/index.php/Contrib/swak4Foam
And an example is here : http://openfoamwiki.net/index.php/Contrib_groovyBC
apatronis May 8, 2013 06:23
Thanks Frédéric.
