[solidMechanics] no output in elasticIncrSolidFoam |
October 14, 2014, 08:40 |
Peter Knapen
Rep Power: 16 |
Hi All,
I am trying to model a droptest in openFoamextend 3.1 solidMechanics. As I am new to openFoam, I first trie to drop a tank (2D) on a floor. I have modeled the tank and floor in Hypermesh and exported the mesh to openFoam. Next I have renamed the name of the walls in the elasticIncrSolidFoam to the names I have used in Hypermesh and commented out the blockMesh line in Allrun. In a later stage the fluid has to be added. As I do not now how to prescribe the initial velocity to the tank, I have prescribed a large displacement in time of the upper outer faces of the tank. The analysis does run and I get results for the contact forces, but the results are not written to the various output directories. Only directory 0 exists. I have attached some of the listing of this problem, any idea what I have to do to get output? Best regards, Peter |
October 15, 2014, 06:05 |
Peter Knapen
Rep Power: 16 |
I found the source of my problem, the output frequency in the controlDict was too high.
How should I impose an initial velocity to the tank nodes (primary variable is displacement not velocity)? Peter |
Display Modes | |
[swak4Foam] outputTime in Swak function | immortality | OpenFOAM Community Contributions | 20 | October 6, 2022 13:08 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 07:16 |
RNG diverged during the analysis the flow over a multi element airfoil, why? | s.m | OpenFOAM Running, Solving & CFD | 0 | August 5, 2013 09:39 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 10:34 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 13:30 |
