-   -   initial residual and final residual (http://www.cfd-online.com/Forums/openfoam-solving/117484-initial-residual-final-residual.html)
mscheng May 9, 2013 04:16
Hi FOAMERs,
what is the definition of the initial residual and final residual, which can be used to decide convergence ?
Anne Lincke May 15, 2013 05:20
The initial residual is evaluated based on the current values of the field before solving an equation for a particular field . The final residual is evaluated after the solution of the equation is performed.
The intial residual is more important to decide whether a computation converges, or not.
timo_IHS May 15, 2013 08:23
Hi Anne,
can you give some rule of thumbs for values, which should be achieved for the initial/final residual and how many iterations should be used for pEqn per cycle e.g. for a transient simulation with a standard PCG solver.
Best Timo
Anne Lincke May 15, 2013 08:29
Initial residual: e^-4 or e^-5 is a good result. Final residual has to be smaller (e^-8).
I cannot answer your 2nd question.
Manm August 17, 2016 15:45
Hi, based on this definition, I was curious as to why the final residual in one time step NOT equal to initial residual in NEXT time step?
blais.bruno August 17, 2016 15:55
Assuming you are solving in steady state, it is because the equations are non-linear.
If you solve the momentum equation for U, at the next iteration, P and phi will have been changed. Therefore, the initial residual will be different from the final residual of the last iteration.
If you were to solve a linear equation, non-coupled with any other variables, in steady-state, then you would solve it in a single iteration... and therefore your "next initial" residual would be your last final one...
Manm August 17, 2016 17:13
Thank you. That helped to understand my question.
If I understand it right,
Say : U =f(p,phi,t) where f is a complex function
If t0 =0:
During 1 st iteration, we start with a p0, phi0 and dt time step and get U1 =f(p0, phi0,dt) as well as p1, phi1 values. The corresponding final error/ residual is calculated from U1 and true U expected.
Before 2nd iteration starts, a (say) U12 is calculated based on new available values:
U12 =f(p1,phi1,dt) and this is used to calculate the initial error/ residual before the 2nd time step starts.
and then we go on to calculate U2 =f(p1, phi1, dt+dt) and corresponding p2, phi2 and final error/ residual at the end of 2nd time step and so on....
blais.bruno August 18, 2016 08:31
Yup, That is exactly so.
OpenFOAM is a segregated solver, that is U, V, W, phi and P are solved segregated. This is why such a thing happen.
There are block coupled solvers in foam-extend, but those are still linear solver and don't implement a non-linear newton method or something like that.
If t0 =0:
