July 28, 2010, 10:46 |
BCs at Inlet and Outlet
Sebastian Saegeler
Rep Power: 16 |
Hi!
As I have just started using Open Foam I would need some help to set a case I want to compare a calculation of a nozzle flow, made with Fluent to one with Open Foam and need to install similar boundary conditions in Open Foam as used in Fluent. At the inlets, in Fluent I have installed pressure-inlets to set up the total pressure. Furthermore, at the outlets, there are defined pressure-outlets with a given static pressure. Now I want to do the same in my OpenFoam case. Which BC would you recommend (also in respect of possible backflow)? Also, which BC should be used for k and epsilon? In Fluent I set the trubulence intensity and the viscosity ratio as fixed values. I think the turbulentIntensityKineticEnergyInlet for k is the corresponding BC in OpenFoam. But what to use for epsilon? Thanks in advance! Regards, Sebastian Last edited by sebastian; July 28, 2010 at 11:08. |
July 29, 2010, 14:11 |
ata kamyabi
Rep Power: 17 |
Hi Sebastian
For full boundary conditions in O.F. see \src\finiteVolume\fields\fvPatchFields folder. Good luck Best regards Ata |
July 30, 2010, 04:09 |
Rep Power: 16 |
This might help as a basic introduction (easy to find with google of forum search...)
http://www.openfoam.com/docs/user/boundaries.php In the folder Ata mentioned, you'll find a totalPressure boundary condition as well. For a fixed (static) back pressure, try fixedValue with the pressure as value. -Andreas. |
May 10, 2013, 22:34 |
sqing
Rep Power: 13 |
Hi Sebastian
Have you set your case correctly? I have met the similar situation as yours, however there are something wrong in my case that I can't figure out. So I want to get some help from you. regards Sunxing |
