mpirun doesn't work after update on 2.2.0
i'm new in this Forum and want to ask: if somebody knows a solution for my Problem, please help me: i've updated only the OpenFOAM Version from 2.0.x on 2.2.0 and now i've the Problem, that mpirun doesn't work any more... This is the Error-Message, which is posted in the Terminal: opal_shmem_base_select failed Also the rhoSimpleFoam solver doesn't work any more, because some Libraries have become new names and new paths, can somebody say me which from the suggested links conforms to this old one out of thermophysicalProperties: thermoType hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>> The suggested libraries are: Valid psiThermo types are: 34 ( hePsiThermo<homogeneousMixture<const<hConst<perfec tGas<specie>>,sensibleEnthalpy>>> hePsiThermo<homogeneousMixture<sutherland<hConst<p erfectGas<specie>>,sensibleEnthalpy>>> hePsiThermo<homogeneousMixture<sutherland<janaf<pe rfectGas<specie>>,sensibleEnthalpy>>> hePsiThermo<inhomogeneousMixture<const<hConst<perf ectGas<specie>>,sensibleEnthalpy>>> hePsiThermo<inhomogeneousMixture<sutherland<hConst <perfectGas<specie>>,sensibleEnthalpy>>> hePsiThermo<inhomogeneousMixture<sutherland<janaf< perfectGas<specie>>,sensibleEnthalpy>>> hePsiThermo<multiComponentMixture<const<hConst<per fectGas<specie>>,sensibleEnthalpy>>> hePsiThermo<multiComponentMixture<sutherland<janaf <perfectGas<specie>>,sensibleEnthalpy>>> hePsiThermo<pureMixture<const<eConst<perfectGas<sp ecie>>,sensibleInternalEnergy>>> hePsiThermo<pureMixture<const<hConst<perfectGas<sp ecie>>,sensibleEnthalpy>>> hePsiThermo<pureMixture<const<hConst<perfectGas<sp ecie>>,sensibleInternalEnergy>>> hePsiThermo<pureMixture<sutherland<eConst<perfectG as<specie>>,sensibleInternalEnergy>>> hePsiThermo<pureMixture<sutherland<hConst<perfectG as<specie>>,sensibleEnthalpy>>> hePsiThermo<pureMixture<sutherland<hConst<perfectG as<specie>>,sensibleInternalEnergy>>> hePsiThermo<pureMixture<sutherland<janaf<perfectGa s<specie>>,sensibleEnthalpy>>> hePsiThermo<pureMixture<sutherland<janaf<perfectGa s<specie>>,sensibleInternalEnergy>>> hePsiThermo<reactingMixture<const<hConst<perfectGa s<specie>>,sensibleEnthalpy>>> hePsiThermo<reactingMixture<sutherland<janaf<perfe ctGas<specie>>,sensibleEnthalpy>>> hePsiThermo<singleStepReactingMixture<sutherland<j anaf<perfectGas<specie>>,sensibleEnthalpy>>> hePsiThermo<veryInhomogeneousMixture<const<hConst< perfectGas<specie>>,sensibleEnthalpy>>> hePsiThermo<veryInhomogeneousMixture<sutherland<hC onst<perfectGas<specie>>,sensibleEnthalpy>>> hePsiThermo<veryInhomogeneousMixture<sutherland<ja naf<perfectGas<specie>>,sensibleEnthalpy>>> heheuPsiThermo<egrMixture<const<hConst<perfectGas< specie>>,absoluteEnthalpy>>> heheuPsiThermo<egrMixture<sutherland<janaf<perfect Gas<specie>>,absoluteEnthalpy>>> heheuPsiThermo<egrMixture<sutherland<janaf<perfect Gas<specie>>,absoluteInternalEnergy>>> heheuPsiThermo<homogeneousMixture<const<hConst<per fectGas<specie>>,absoluteEnthalpy>>> heheuPsiThermo<homogeneousMixture<sutherland<janaf <perfectGas<specie>>,absoluteEnthalpy>>> heheuPsiThermo<homogeneousMixture<sutherland<janaf <perfectGas<specie>>,absoluteInternalEnergy>>> heheuPsiThermo<inhomogeneousMixture<const<hConst<p erfectGas<specie>>,absoluteEnthalpy>>> heheuPsiThermo<inhomogeneousMixture<sutherland<jan af<perfectGas<specie>>,absoluteEnthalpy>>> heheuPsiThermo<inhomogeneousMixture<sutherland<jan af<perfectGas<specie>>,absoluteInternalEnergy>>> heheuPsiThermo<veryInhomogeneousMixture<const<hCon st<perfectGas<specie>>,absoluteEnthalpy>>> heheuPsiThermo<veryInhomogeneousMixture<sutherland <janaf<perfectGas<specie>>,absoluteEnthalpy>>> heheuPsiThermo<veryInhomogeneousMixture<sutherland <janaf<perfectGas<specie>>,absoluteInternalEnergy> >> ) Sorry about my Englisch, that is still not Perfect=) Thx for your supply... |
Hi Marcus,
Did you edit the .bashrc file after installing version 2.2? Best Regards, Paulo |
Hi Paulo,
at first thx for your supply... yes the Problem with the Bash I solved (bashRC in Home/openfoam/): if [ -f /etc/bashrc ]; then . /etc/bashrc fi # User specific aliases and functions #########OpenFOAM 2.2.0 ######## source /usr2/shared1/OpenFOAM/OpenFOAM-2.2.0/etc/bashRCand in the bash file of the OpenFOAM install directory, i typed the following: foamInstall=/usr2/shared1/$WM_Project if i run something the right version 2.2.0 will be shown in the terminal... But now i have the Problem, that my old Cases don't run anymore, with the old thermophysicalProperties file and now my Problem is which psiThermo type i've to use to solve my compressible rhoSimpleFoam case... The Mpirun Problem i also don't fix...Can you say me also sth. for this Problem please. Many thx... MfG Marcus |
Hi Marcus,
What about the tutorials? Did you verify which of them are working correctly and which are not? Best Regards, Paulo |
Same error
Hello, I get the same error after upgrading to OF2.2 on CentOS release 6.4 (Final). For example, tutorials/incompressible/simpleFoam/motorBike :
$ mpirun -np 6 simpleFoam -parallel |
Hi Marcus and mstachon,
I suspect that some keyword in your installation is not correctly defined, but I don't know how to test this. Were you able to run the parallel breaking dam tutorial that appears in item 2.3.11 of the user guide? Best Regards, Paulo |
Greetings to all!
@mstachon: This is the second time I see this error message in the last couple of days... check the instructions from here: http://www.cfd-online.com/Forums/ope...tml#post428368 - post #5 Additionally, since you're using CentOS 6.4, check these installation instructions: http://openfoamwiki.net/index.php/In...CentOS_SL_RHEL @marcus: Read these instructions: http://www.openfoam.org/version2.2.0....php#x10-40000 - namely section "Dictionary-based Thermodynamics Selection" Best regards, Bruno |
Fixed!
I have followed the instructions from http://www.cfd-online.com/Forums/ope...tml#post428473 and now it works! Thanks for the references.
