May 15, 2013, 01:02 |
Mapping data for every time step
Luca
Rep Power: 13 |
Hi everybody.
I running a case of a flow inside a rough channel with an LES model. Now i would like to pick the data from an "inner" plane of the volume for every time step and use it as inlet data for other cases. The "problem" is that I don't want to map only the latest time, but all the time steps so that i can maintain the turbulence that i generated. Is this possible? To do this i need to save the data for every time step with Code:
writeControl timeStep; writeInterval 1; To avoid HUGE output files, is it possible to save datas only from a particular plane? Has it to be a patch? If yes, how can i create a patch inside my domain? I found this post (http://www.cfd-online.com/Forums/ope...tml#post245855) but I didn't understood if with this method i map all the time steps or only the last one. Thank you very much. |
May 20, 2013, 00:18 |
Luca
Rep Power: 13 |
No one can give me some hint?
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 03:41 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Data conversion at each time step for specific fields | melanie | OpenFOAM Post-Processing | 10 | September 29, 2009 17:34 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 00:36 |
