Home > Forums > OpenFOAM Running, Solving & CFD
Moving mesh problem
Old   May 17, 2013, 17:26
Default Moving mesh problem
kilroy's Avatar
kilroy is on a distinguished road
I have just gone through the OpenFOAM's movingCone tutorial. I can see that, as the object moves to the right side, mesh on the right side is contracting and the mesh on the left side of the object is expanding. Please see the pictures attached (movingCone_initial.png and movingCone_last.png)
After that, I tried to apply the same principles to a ship traveling through calm water making a 45 degree angle with the stream. I want to make the ship move 4 times the length of the ship, but my run crashes a little bit after the start. I think that is because the distortion of the mesh. Please see the pictures attached (ship_initial and ship_last)
Do you know if there is a way to overcome that distortion problem? (Like updating and recreating the mesh in each step)
Thank you very much for your help in advance,
Kilroy
kilroy is offline   Reply With Quote
Old   May 18, 2013, 03:22
HECKMANN Frédéric
fredo490 is on a distinguished road
Basically you try to use a 2D example and run it in 3D... Well, it is always a mess. Moreover, the example you took uses a structured mesh while you use an unstructured mesh. If I understand well, you want to use the layer add/remove solver ?
For displacement into an unstructured mesh, I usually use the Laplacian solver. But this kind of technique is not very good for large dispalcements.
dynamicMeshDict file:
dynamicFvMesh      dynamicMotionSolverFvMesh;
motionSolverLibs ("libfvMotionSolvers.so");
solver            displacementLaplacian;
displacementLaplacianCoeffs
    diffusivity       quadratic inverseDistance (wall);
What you can try is to create 3 different areas. Two structured on each side of your domain and in the middle you put your boat. You then have to translate all your middle area (with the boat) so that the 2 areas on the side take the motion by adding/removing layers.
fredo490 is offline   Reply With Quote
Old   May 20, 2013, 16:36
kilroy's Avatar
Frederic,
Thank you very much for your response. Dividing the computational domain into three parts is a very good idea, but I have no experience with that.
Do you know any example or tutorial for OpenFOAM, that applies the principles that you have described above?
Sincerely,
Kilroy
Thread Tools
Trackbacks are On
How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 06:54
2D Mesh Generation Tutorial for GMSH aeroslacker Open Source Meshers: Gmsh, Netgen, CGNS, ... 12 January 19, 2012 04:52
snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Native Meshers: snappyHexMesh and Others 2 March 27, 2011 21:11
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
Moving mesh problem Jan Majer CD-adapco 2 June 10, 2003 04:19
