Home > Forums > OpenFOAM Running, Solving & CFD
passive scalar increases
Like Tree5Likes
Old   May 23, 2013, 15:21
immortality's Avatar
Ehsan
immortality is on a distinguished road
thank you for your full clarification.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   May 25, 2013, 16:16
Ehsan
Hi again!
and what will be the proper code for an incompressible case? I wrote sp(rho,gas) in pimpleFoam and it got an error and when removed rho from equation in got another error:an Error in compiling:Foam::zeroField Foam::fvm::Sp(const Foam::zero&, const Foam
so whats the correct equation?
Old   May 26, 2013, 04:17
Tobi's Avatar
Tobias Holzmann
Tobi will become famous soon enoughTobi will become famous soon enough
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Originally Posted by immortality View Post
Hi again!
Hi
ddt(phi, gas)
should work
Tobi is offline   Reply With Quote
Old   May 26, 2013, 05:30
Ehsan
Hi,sure it needs to be modified:
fvScalarMatrix gasEqn
	  fvm::ddt(phi,gas)
         -fvm::Sp(phi, gas)
         +fvm::div(phi, gas)
         -fvm::Sp(fvc::div(phi), gas)
         -fvm::laplacian(turbulence->nuEff(), gas)
	gasEqn.relax();
	gasEqn.solve(mesh.solver("gas"));
this error occurred:
Making dependency list for source file pimpleFoamModified.C
SOURCE=pimpleFoamModified.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam220/src/turbulenceModels/incompressible/turbulenceModel -I/opt/openfoam220/src/transportModels -I/opt/openfoam220/src/transportModels/incompressible/singlePhaseTransportModel -I/opt/openfoam220/src/finiteVolume/lnInclude -I/opt/openfoam220/src/meshTools/lnInclude -I/opt/openfoam220/src/fvOptions/lnInclude -I/opt/openfoam220/src/sampling/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/pimpleFoamModified.o
In file included from pimpleFoamModified.C:89:0:
gasEqn.H: In function ‘int main(int, char**)’:
gasEqn.H:5:20: error: no matching function for call to ‘ddt(Foam::surfaceScalarField&, Foam::volScalarField&)’
gasEqn.H:5:20: note: candidates are:
/opt/openfoam220/src/finiteVolume/lnInclude/fvmDdt.C:45:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::ddt(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam220/src/finiteVolume/lnInclude/fvmDdt.C:60:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::ddt(const Foam::one&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam220/src/finiteVolume/lnInclude/fvmDdt.C:72:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::ddt(const dimensionedScalar&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam220/src/finiteVolume/lnInclude/fvmDdt.C:88:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::ddt(const volScalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
gasEqn.H:6:27: error: no matching function for call to ‘Sp(Foam::surfaceScalarField&, Foam::volScalarField&)’
gasEqn.H:6:27: note: candidates are:
/opt/openfoam220/src/finiteVolume/lnInclude/fvmSup.C:100:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::Sp(const Foam::DimensionedField<double, Foam::volMesh>&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam220/src/finiteVolume/lnInclude/fvmSup.C:126:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::Sp(const Foam::tmp<Foam::DimensionedField<double, Foam::volMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam220/src/finiteVolume/lnInclude/fvmSup.C:140:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::Sp(const Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam220/src/finiteVolume/lnInclude/fvmSup.C:154:1: note: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::Sp(const dimensionedScalar&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam220/src/finiteVolume/lnInclude/fvmSup.C:180:1: note: template<class Type> Foam::zeroField Foam::fvm::Sp(const Foam::zero&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
make: *** [Make/linux64GccDPOpt/pimpleFoamModified.o] Error 1
Old   May 26, 2013, 13:18
Tobi's Avatar
Tobias Holzmann
Sorry... my fault:
fvm::ddt(gas)
Old   May 26, 2013, 13:52
Ehsan
Hi tobias
I changed it:
	  fvm::ddt(gas)
         -fvm::Sp(phi, gas)
         +fvm::div(phi, gas)
	gasEqn.relax();
but the error persists:
ehsan@Ehsan-com:~/Desktop/Solvers/pimpleFoamModified$ wmake
maybe the Sp term should be removed?
I don't know yet exactly when we have to use Sp term.could you please clarify again for me?
Old   December 25, 2013, 11:46
Ehsan
Hi dear Tobias
this link has been broken,could you give me another link for referencing? thanks.
http://www.holzmann-cfd.de/index.php...rische-schemen
Old   December 25, 2013, 13:03
Bruno Santos
wyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nicewyldckat is just really nice
Greetings to all!
@Ehsan:
Hi dear Tobias
If think the new link is this one: http://www.holzmann-cfd.de/index.php/numerische-schemen
Best regards,
Bruno
Tobi likes this.
Tobi's Avatar
Tobias Holzmann
Hi Ehsan,
here is the actual link:
wyldckat likes this.
Old   January 13, 2014, 11:52
TBO
TBO is on a distinguished road
Originally Posted by Tobi View Post
For that I build a new one with two different densitys (not tested).
Hi Tobi,
A while ago you also mentioned this solution to me on the libOpenSmoke forum. However I think it is more appropriate to ask you here, since this is about the scalar solver. Can you share your solver with two different densities for the mixing of air and methane? As background, I want to model the mixing of a fuel (methane) with air.
Regards,
TBO is offline   Reply With Quote
Old   January 14, 2014, 12:38
Ehsan
Hi dear Tobias,
for an unsteady flow,are these schemes appropriate?is bounded scheme suitable for ddt(rho,gas)? the results seemed fine and now I noticed about maybe excess "bounded" term in schemes.are they OK in your opinion?
  ddtSchemes
    default         none;
    ddt(rho)        CrankNicolson .5;
    ddt(rhoU)       CrankNicolson .5;
    ddt(rhoE)       CrankNicolson .5;
    ddt(rho,U)      CrankNicolson .5;
    ddt(rho,e)      CrankNicolson .5;
    ddt(rho,h)      CrankNicolson .5;
    ddt(rho,k)      bounded CrankNicolson .5;
    ddt(rho,omega)  bounded CrankNicolson .5;
    ddt(rho,epsilon) bounded CrankNicolson .5;
    ddt(rho,gas)    bounded CrankNicolson .5;
  divSchemes
    default none;
    div(tauMC) Gauss linear;
    div(phi,k) bounded Gauss upwind;
    div(phi,omega) bounded Gauss upwind;
    div(phi,epsilon) bounded Gauss upwind;
    div(phi,gas) bounded Gauss limitedLimitedLinear 1 0 1;
and its the transport equation:
     // --- Scalar Transport( Solving equation of variance of mixture fraction )
      tmp<fvScalarMatrix> gasEqn
       fvm::ddt(rho,gas)
        -fvm::Sp(fvc::ddt(rho), gas)
        +fvm::div(phi, gas)
        -fvm::laplacian(turbulence->muEff(), gas)
      gasEqn().relax();
      gasEqn().solve(mesh.solver("gas"));
Old   January 14, 2014, 13:32
Tobi's Avatar
Tobias Holzmann
Originally Posted by TBO View Post
Hi Tobi,
Regards,
yes I have that solver - anywhere on my Harddisc -
Is it possible that you share your results?
Regards Tobi
PS: Further answer to the schemes is comming (no time at the moment)
Old   January 23, 2014, 09:47
TBO
Regards Tobi
Hi Tobi,
I would be very happy to test this solver, since it would help a lot to model a steady state mixing of gases with different densities. My main goal is to run combustion simulations (with the use of libOpenSmoke/ flameletSimple/PisoFOam). However as step before and to assess nozzle designs I would like to model fuel and air mixing without chemical reactions involved, for this the scalar solver could be very helpful, since steady state is almost the only option.
The simulations I am doing on real geometries are strictly confidential, so there is no way of sharing them . For the cold flow mixing I will also run some academic cases (when I have time...) and it should be possible to share some of those results.
Mit freundlichen Grüßen,
Thread Tools
Trackbacks are On
dieselFoam problem!! trying to introduce a new heat transfer model vivek070176 OpenFOAM Programming & Development 10 December 24, 2014 00:48
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 01:47
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 11 April 22, 2014 12:32
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
passive scalar for carbon monoxide kraizy STAR-CCM+ 0 October 12, 2009 20:13
