-   -   groovyBC_2Way_Coupling_001 example (http://www.cfd-online.com/Forums/openfoam-solving/118083-groovybc_2way_coupling_001-example.html)
haze_1986 May 21, 2013 00:21
Hi all, I am not sure if this example is made to work on OF 2.1.1 as I had issues with it. For a start, it can't seem to read the timeVaryingUniform BC and has to be changed to
inlet
type uniformFixedValue;
uniformValue tableFile;
tableFileCoeffs
fileName "pressureRamp";
outOfBounds clamp;
value $internalField;
Running it now produces the following error:
--> FOAM FATAL ERROR:
Parser Error at "1.21-27" :"field Q_int11 not existing or of wrong type"
"(Q_int12 + U_relax*(Q_int11 - Q_int12))/sum(mag(Sf()))*normal()"
From function parsingValue
in file lnInclude/CommonValueExpressionDriverI.H at line 802.
FOAM exiting
Then I tried removing the Q_int11 just as a trial.
Now the error becomes:
--> FOAM FATAL IO ERROR:
attempt to read beyond EOF
file: /home/caelinux/OpenFOAM/caelinux-2.1.0/run/tutorials/incompressible/simpleFoam/groovyBC_2Way_Coupling_001/system/fvSchemes::divSchemes::default at line 41.
From function ITstream::read(token&)
in file db/IOstreams/Tstreams/ITstream.C at line 83.
FOAM exiting
gschaider May 21, 2013 05:12
inlet
tableFileCoeffs
outOfBounds clamp;
FOAM exiting
FOAM exiting
Could you please start again? The boundary condition you're specifying (uniformFixedValue) has got nothing to with the error message you're posting (which is from swak/groovyBC) and the fix you're doing.
The problem in fvSchemes is certainly unrelated to the boundary condition thing. If I understand your initial sentence correctly this is a case that used to work with an old OF version but now doesn't work anymore (but it is not even clear to me whether you upgraded from or to 2.1.1): the error message you show is typical for instances where some more information is expected before the ';'. My suggestion: check fvSchemes in the tutorials relevant for your solver in the old OF-version (where it used to work) and in the new version and see what changed
haze_1986 May 21, 2013 05:18
Hi, would like to clarify, in the example the inlet type is timeVaryingUniform BC and I read somewhere that it is no longer in OF2.1.1 (I installed this version from scratch)
I also read that changing it to the BC above in blue will fix it. Seems that it fixes to run in 2.1.1 but there are more errors as shown above. Is it due to changing the BC or is it something inherent that I am missing out? Or is it version difference causing it?
Could you please recommend which version should I run it in? So I can try again. Thanks.
gschaider May 21, 2013 05:53
Took me some googling to find out which case you're talking about: it's the one downloaded from http://openfoamwiki.net/index.php/Contrib_groovyBC, right? The problem is that this case is quite old and probably uses a syntax for coupling boundary conditions that is not supported anymore. See the swak-page. "Q_int11@interface11" is now written as "Q_int11{patch'interface11}". That's why it was not found in your initial post. Because it was evaluated on the same patch and assigned to a variable Q_int11@interface11
The problem with fvSchemes is almost certainly there because the case is rather old. Copy over a schemes-file from one of the current simpleFoam-tutorials and you should be fine (same for fvSolution: I'm sure you're going to see problems there too).
haze_1986 May 21, 2013 08:23
Hi I have just did as you advised, still the exact same problem. Schemes files from pitzDaily example.
gschaider May 21, 2013 14:23
It is not clear to me what you mean with "Exact same problem". The problem with the boundary conditions or fvScheme?
haze_1986 May 21, 2013 19:36
Hi, both problems. It is exactly the same.
gschaider May 22, 2013 09:52
Currently we can only guess what you changed about your files. So please post the pressure file that you adapted to the new syntax.
fvSolution is definitely not a problem of swak. Check that you really use an updated version
haze_1986 May 22, 2013 10:00
Hi, appreciate your help
P
dimensions [0 2 -2 0 0 0 0];
internalField uniform 1176.471;
boundaryField
fixedWalls
type zeroGradient;
inlet
tableFileCoeffs
outOfBounds clamp;
outlet
type fixedValue;
interface11
type groovyBC;
variables "p_int12@interface12=sum(p*mag(Sf()))/sum(mag(Sf()));p_int11=sum(p*mag(Sf()))/sum(mag(Sf()));p_relax=0.3;";
valueExpression "(p_int11 + p_relax*(p_int12 - p_int11))";
interface12
type zeroGradient;
interface21
type groovyBC;
variables "p_int22@interface22=sum(p*mag(Sf()))/sum(mag(Sf()));p_int21=sum(p*mag(Sf()))/sum(mag(Sf()));p_relax=0.3;";
valueExpression "(p_int21 + p_relax*(p_int22 - p_int21))";
interface22
type zeroGradient;
fvSolution
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0.01;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0.1;
k
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
epsilon
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
R
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
nuTilda
solver PBiCG;
tolerance 1e-05;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 0;
residualControl
p 1e-2;
U 1e-3;
"(k|epsilon|omega)" 1e-3;
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.7;
epsilon 0.7;
R 0.7;
nuTilda 0.7;
fvSchemes
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
div(phi,R) Gauss upwind;
div(R) Gauss linear;
div(phi,nuTilda) Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default none;
laplacian(nuEff,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
gschaider May 22, 2013 10:23
Originally Posted by haze_1986 (Post 429238)
interface21
type groovyBC;
It is a bit hard to help you if you don't read my answers: I quote from my previous message
haze_1986 May 22, 2013 10:36
sorry about that, changed the U but forgot about the p, thanks for you help.
