Home > Forums > OpenFOAM Running, Solving & CFD
Equation Solving in Multiphase Flow
Like Tree2Likes
  • 1 Post By Tobi
  • 1 Post By Tobi
Old   May 21, 2013, 05:14
Default Equation Solving in Multiphase Flow
andreas is on a distinguished road
Dear foamers,
I would like to know how are the Navier-Stokes equations solved in a multiphase flow.
Let's consider a liquid/air flow. When a mesh is full of liquid or air, the equation resolution is similar to a monophasic fluid flow.
But when a cell is partially filled with liquid and gas, are the equations solved for each phase fraction? Maybe the density and other parameters are averaged for each cell?
Thank you for your time,
Andreas
andreas is offline   Reply With Quote
Old   May 21, 2013, 07:22
Tobi's Avatar
Tobias Holzmann
Tobi will become famous soon enoughTobi will become famous soon enough
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi Andreas,
Ive been working with the interFoam solver many times.
For the density you are creating a averaged density in that cell for the beginning:
00037     const dimensionedScalar& rho1 = twoPhaseProperties.rho1();
00038     const dimensionedScalar& rho2 = twoPhaseProperties.rho2();
00039
00040
00041     // Need to store rho for ddt(rho, U)
00042     volScalarField rho
00043     (
00044         IOobject
00045         (
00046             "rho",
00047             runTime.timeName(),
00048             mesh,
00049             IOobject::READ_IF_PRESENT
00050         ),
00051         alpha1*rho1 + (scalar(1) - alpha1)*rho2,
00052         alpha1.boundaryField().types()
00053     );
00054     rho.oldTime();
First you extract the value of the density for phase1 and phase2 out of the properties file and then creating a averaged density:
After that every time step execute the following line:
00082         twoPhaseProperties.correct();
In that function (object=twoPhaseProperties; function=correct()) you should find the calculation of the thermophysical variables depending on Phase1 and Phase2.
Hope that is helpful.
Tobi
sharonyue likes this.
Tobi is offline   Reply With Quote
Old   May 21, 2013, 14:01
Hello Tobi, and thank you for your answer.
I am working on interFoam as well!
What you are saying is that the density is averaged on each cell automatically?
What about other parameters? Is pressure averaged as well?
And finally, are the Navier-Stokes solved for these averaged values? Or maybe for each phase fraction on each cell.
Thank you,
Andreas
Old   May 21, 2013, 14:13
Tobi's Avatar
Tobias Holzmann
first
p == p_rgh + rho*gh;
So you can see that p is calculated with the averaged density.
and p_rgh is calculated as:
        fvScalarMatrix p_rghEqn
            fvm::laplacian(rAUf, p_rgh) == fvc::div(phiHbyA)
The variables rAUf, phiHbyA is calculated in pEqn.H befor.
I am familiar with the code of standard solvers for compressible and incompressible flows but not for multiphase.
For that I can not give you an exact answer.
For the velocity:
    fvVectorMatrix UEqn
        fvm::ddt(rho, U)
      + fvm::div(rhoPhi, U)
      + turbulence->divDevRhoReff(rho, U)
    UEqn.relax();
As you can see there are the averaged values again.
But the averages are just in those cells with 0 < alpha < 1
Thread Tools
Trackbacks are On
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 7 April 16, 2014 03:38
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
why divergence occures in these cases immortality OpenFOAM Running, Solving & CFD 2 January 25, 2013 11:21
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
