August 28, 2019, 04:51 |
Back Flow in 3D Dam Break
Sajjad Haider
Rep Power: 14 |
I am solving the 3D dam break case in OF 5.0 with flow hitting an obstacle. I created a reservoir in the initial part and used setFields to place 40 cm of water. I defined walls all around the domain. The BC for 'atmosphere' patch is 'inletOutlet'. The calculation with interFoam goes to completion smoothly. The problem is that viewed in paraFoam, the flow does not go forward (does not enter the channel) but recedes backward and after a second or so there is no water. I need your help about how to plug the escape of water and make simulation work. |
Display Modes | |
3D dam break flow problem | woochang | CFX | 1 | February 18, 2010 16:47 |
back flow at pressure out flow boundary condition | durga | Main CFD Forum | 0 | December 8, 2009 00:42 |
how to specify Back flow Temperature? | Rya | FLUENT | 0 | April 12, 2006 03:38 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
Dam break pictures | Renato. | Main CFD Forum | 0 | February 3, 2006 09:33 |
