Home > Forums > OpenFOAM Running, Solving & CFD
Problem to run kEpsilonSST in OpenFOAM
Old   May 22, 2013, 10:28
Default Problem to run kEpsilonSST in OpenFOAM
Anselme Bonnet
OpenF is on a distinguished road
Hi everyone,
I'm trying to adapt the tutorial "motorBike" which contains kEpsilonSST turbulence model to my own case "the Backward facing step".
I'm not running in parallel. I just implemented the classical files to run a computation.
The computation starts and the residuals look good except "time step continuity errors" which crash.
I don't understand where the problem is. My boundaries conditions seem good.
I get this error in the terminal.
Time = 33
smoothSolver:  Solving for Ux, Initial residual = 0.545989, Final residual = 0.0462827, No Iterations 34
smoothSolver:  Solving for Uy, Initial residual = 0.495099, Final residual = 0.0440825, No Iterations 28
GAMG:  Solving for p, Initial residual = 0.999999, Final residual = 0.104651, No Iterations 1000
time step continuity errors : sum local = 7.15765e+24, global = -1.17591e+21, cumulative = -1.17591e+21
smoothSolver:  Solving for omega, Initial residual = 0.962478, Final residual = 0.0860166, No Iterations 18
smoothSolver:  Solving for k, Initial residual = 0.53023, Final residual = 2.24728e-06, No Iterations 1
ExecutionTime = 61.86 s  ClockTime = 62 s
Time = 34
smoothSolver:  Solving for Ux, Initial residual = 0.388555, Final residual = 192672, No Iterations 1000
smoothSolver:  Solving for Uy, Initial residual = 0.448615, Final residual = 32484.1, No Iterations 1000
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/simpleFoam"
#9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
I will be very grateful if someone could help me ! If necessary I can provide other files.
Best regards,
Anselme
OpenF is offline   Reply With Quote
Thread Tools
Trackbacks are On
Problem running OpenFOAM 2.2.x in parallel in Centos 5 lvalvare OpenFOAM Running, Solving & CFD 30 July 2, 2016 13:00
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
how run a DNS for ZPG turbulent boundary layer on a plate with OpenFOAM? dictatore_bozorg OpenFOAM Meshing & Mesh Conversion 3 October 9, 2015 05:08
Can not run OpenFOAM in parallel in clusters, help! ripperjack OpenFOAM Running, Solving & CFD 5 May 6, 2014 15:25
How can i run case in OpenFOam? premal OpenFOAM 2 June 24, 2012 00:58
