error on linearUpwind
what does mean this error when using linearUpwind instead of upwind?why can't use linearUpwind?
2] in file /opt/openfoam220/src/finiteVolume/lnInclude/surfaceInterpolationScheme.C at line 82. |
Hi Ehsan,
Summarizing the error message: Code:
Unknown discretisation scheme linearUpwind I could be (or probably am) wrong, but from the very little I know on this topic, not all fields need to be calculated using second order schemes for the simulation to be considered to be valid. Best regards, Bruno |
Hi Bruno
thanks.it resolved.is tauMC related to viscous terms or how can find its formula? |
Hi Ehsan,
I ran this command inside one of your modified solvers: Code:
grep "tauMC" * Code:
rhoCentralFoamModified.C: volTensorField tauMC("tauMC", muEff*dev2(Foam::T(fvc::grad(U)))); Best regards, Bruno |
