yes.it should be for that reason.
could you please have a look into the main case also? |
Uhm... I have the case running in serial (sequential mode) for over 600 seconds already and it hasn't crashed yet.
At which time step is it meant to crash? |
this simple case doesn't crash,although the values of turbulence variales increase constantly.which value is suitable to be used in internal field and enterance?are the current values proper?
And crashing occurs in the case with groovyBC. |
Hi Ehsan,
As tired as I am, I'm trying to figure out what to suggest. This is unfortunately waaaay beyond my level of experience. From what I can figure out, "omega" shoots up to very high values at the walls, due to the sudden pressure/mass flow intake. I think that injecting higher values of k-omega won't affect the results... the pressure difference is simply too high. Either that, or the initial pressure is already too high inside the domain, leading "omega" to increase so much!? OK, there are several layers of complexity at work here and you'll have to isolate one at a time:
And that's pretty much all I can figure out to suggest :( Good luck! Bruno |
thanks Bruno for your time and effort
Did you do tests on simple case with constant entrance height? Please have a look into the case with groovyBC to see wich values are appropriate. Feel free to change turbulence and other values to make it work. you have a more well ordered way to investigate things than me. Thanks |
Hi Bruno,
At the moment I have no zero parameters in my boundary conditions nor initial conditions. I am trying to implement the SST k-omega solver for the conjugate heat transfer problem and I get this error which I don't quite understand. I was able to get the case working for a k-epsilon; however, for some strange reason when I change the solver and add values for kappat, nut, and omega the solver crashes. I was wondering if you could please help me understand what is this message exactly saying. Where is the equation being divided by zero and what is causing it? Cheers! Code:
Selecting turbulence model type RASModel |
Dear Lucas,
I guess there is something wrong with your mesh. Please run below code and post the result. Code:
checkMesh -allGeometry -allTopology CFDUser_ |
Greetings Lucas,
To know better which exact division is giving the problem, you would have to build the Debug version: http://openfoamwiki.net/index.php/HowTo_debugging But my guess is that the new fields you've added, there were some that you initialized with 0, which as stated in post #2, is wrong. Best regards, Bruno PS: Please wrap code output with the "[CODE]" markers, as explained in my signature link: Posting code and output with [CODE] |
Hey Bruno,
Thanks for the help! I got it working. The F2() parameter depends on the inverse of the velocity field. Initially I left it set as (0 0 0) but I made a minor change and it worked. Sorry about the code, I was not aware about the link you posted. Thanks for letting me know! Cheers! |
