[PyFoam] how to interrupt pyFoamPlotWatcher.py |
May 28, 2013, 05:18 |
peter fox
Rep Power: 14 |
What is the most suitable way to interrupt the excellent pyFoam tool pyFoamPlotWatcher.py?
I do not want to interrupt the simulation, I just want to stop the watcher such that I again have access to the command line. When press CTRL+C, i do get the message "Watcher: keyboard interrupt", but nothing else happens afterwards. thanks in advance |
May 28, 2013, 07:57 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
The workaround is to suspend the watcher with CTRL-Z and then kill it with "kill %3" (or whatever is the number that was written by the shell). Alternatively you can of course kill with the PID you get with ps
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
May 28, 2013, 08:24 |
peter fox
Rep Power: 14 |
Thanks for the answer. The problem happens all the time (although I have used the tool only for one case so far)...
i will go ahead with the CTRL-Z workaround. |
Display Modes | |
[PyFoam] Using pyFoamPlotWatcher.py To Plot Residuals | m_ridzon | OpenFOAM Community Contributions | 22 | January 26, 2021 19:48 |
Interrupt control during system coupling? | khhan0543 | CFX | 0 | November 28, 2017 02:32 |
Interrupt Control for a expression-based monitor | kohyar | CFX | 2 | December 1, 2016 09:53 |
[ICEM] ICEM CFD Interrupt function | Whitebear | ANSYS Meshing & Geometry | 2 | April 23, 2015 03:47 |
logical expression for cfx interrupt control | wjy-c | CFX | 0 | November 29, 2013 05:30 |
